Buddy needs help 01 1500 4x4 #1897772
08/23/15 05:17 PM
08/23/15 05:17 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
His 01 1500 4x4 has lost it's brakes and it won't go into gear. Are these related? He has replaced lines and hoses and has peddle when sitting but looses it when started. Could this be related to ABS? Maybe a bad master cylinder?
Re: Buddy needs help 01 1500 4x4 [Re: wedgeheaded] #1898854
08/25/15 03:37 AM
08/25/15 03:37 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Can't see them related. Did this happen at the same time? First "won't go in gear" I assume you have a automatic. Fluid level,linkage problem? Brakes "looses it" pedal goes right to the floor?
Re: Buddy needs help 01 1500 4x4 [Re: wedgeheaded] #1898942
08/25/15 11:17 AM
08/25/15 11:17 AM
Friendly, WV
Friendly, WV
He bought this truck for his son to fix up. Yes, auto. It starts fine and runs good. It had bad brake lines so he replaced those with plans of loading it onto his trailer. I think he has a bad master cyl. That doesn't explain the not going into gear. He is thinking it's ABS related. I don't have a clue. Probably unrelated except for neglect.
Re: Buddy needs help 01 1500 4x4 [Re: wedgeheaded] #1899651
08/26/15 11:14 AM
08/26/15 11:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
won't go into gear as in: gear shift won't move? or gear shift moves, but trans does nothing? We've got to "assume" it's the second choice here, and if so, I'd suspect a bad pump.
Re: Buddy needs help 01 1500 4x4 [Re: wedgeheaded] #1899757
08/26/15 02:23 PM
08/26/15 02:23 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
T case in neutral?
Angry white pureblood male
Re: Buddy needs help 01 1500 4x4 [Re: wedgeheaded] #1901209
08/28/15 05:23 PM
08/28/15 05:23 PM
Friendly, WV
Friendly, WV
As to the last two posts, I don't know. It's my friends truck and all my info is second person. I know he dropped the drive shaft to get it loaded. Sorry, wish I had better info for you guys. I was hoping it might ring a bell with somebody, that's all.
