measurements needed? #1897021
08/22/15 09:35 AM
08/22/15 09:35 AM
western mass
K
kathys bird Offline OP
K
western mass
can someone please assist me with the front shock tower
measurements on a 70 E body.
hole to hole.
thanks
Re: measurements needed? [Re: kathys bird] #1897276
08/22/15 08:10 PM
08/22/15 08:10 PM
I can get you a number by Sun eve when I am over there.
Re: measurements needed? [Re: kathys bird] #1897326
08/22/15 10:09 PM
08/22/15 10:09 PM
western mass
K
K
western mass
thanks rob
Re: measurements needed? [Re: RapidRobert] #1897920
08/23/15 09:43 PM
08/23/15 09:43 PM
from the lower bolt hole center up to the slight raised thin "washer" welded on the underside of the shock tower (its OD is slightly greater than the cupped shock washers that capture the neoprene bushing I got 15.5" loaded and 16" with the LCA hanging free
Re: measurements needed? [Re: kathys bird] #1898335
08/24/15 02:40 PM
08/24/15 02:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
hole to hole.
thanks
From one side of the engine compartment to the other ?
