Voltage Regulator for 68 Charger 383-4?
#1896245
08/20/15 09:40 PM
08/20/15 09:40 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
Where can I get an original looking voltage regulator for my 68 Charger?
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Voltage Regulator for 68 Charger 383-4?
[Re: triple_green]
#1896302
08/20/15 11:17 PM
08/20/15 11:17 PM
Posts: 35,979 Lincoln Nebraska
RapidRobert
mrrandyj@aol.com iirc $29 to your door.(hope I spelled his address correctly) OE black case/electronic innards
[Re: triple_green]
#1896454
08/21/15 11:06 AM
08/21/15 11:06 AM
Posts: 20,462 Niles , Ohio
therocks
Its Lost
Its Lost
Niles , Ohio
Almost any parts store also.The new electronic ones are the cats a--.Only reason to use an old points type is a resto that a point car.The new ones the old box will even fit over most.Rocky
Chrysler Firepower
