Peeling clearcoat fix ? #1895797
08/20/15 10:07 AM
08/20/15 10:07 AM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Search came up a little empty .
I'm picking up a 2001 Ram and the clearcoat is peeling in the usual places , is there a cheap fix for this , I really don't want to get into a repaint of the truck.
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895800
08/20/15 10:12 AM
08/20/15 10:12 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Nope. Need to paint it. Scuffing and re-clearing it will look awful. You'd be better off leaving it alone instead of doing that.
Earning every penny of that moderator paycheck.
DBAP
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895805
08/20/15 10:21 AM
08/20/15 10:21 AM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Looks like a hot rod black truck is in my future then ?
It's got 326,000 miles on it and painting it is not going to happen ...
thanks
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895808
08/20/15 10:25 AM
08/20/15 10:25 AM
Hot rod black is probably the smart move if A) the peeling clear bothers you, and B) you want it fixed on the cheap.
DBAP
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895832
08/20/15 11:19 AM
08/20/15 11:19 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Sorry for the hijak, but this is why I will never use clear coat again. Single stage only for me. My '92 Dakota and '98 Ram both had bad clear coat failure. Wondering when the '03 Durango and '11 Nitro will start. Is there a prevention measure? I don't have a garage (that can be parked in wink )
Scott
Re: Peeling clearcoat fix ? [Re: Scott Carl] #1895836
08/20/15 11:21 AM
08/20/15 11:21 AM
Chrysler and GM have had significant problems at times with delaminating clear coats, and in some cases, delaminating base coats, but that's a reflection on their paint suppliers and their prep/paint process and equipment, not on base/clear finishes in general.
I'd never spend my time and money painting something single stage unless I was doing an OE resto. Just my $.02.
DBAP
Re: Peeling clearcoat fix ? [Re: not_a_charger] #1895851
08/20/15 11:58 AM
08/20/15 11:58 AM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
That would be yes to both , I could even just sand it and single stage it. It's pretty much rust free just a bunch of scratches and dings ... maybe I'll revisit the roll your own paint thread?
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895856
08/20/15 12:06 PM
08/20/15 12:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Glad to see you finally got a truck, looks real nice in the picture. up
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895860
08/20/15 12:09 PM
08/20/15 12:09 PM
Roll-on bedliner for the silver parts, quick fix on the dings, scuff, shoot it hot rod black, and be done with it. Easy. punkrocka
DBAP
Re: Peeling clearcoat fix ? [Re: not_a_charger] #1895900
08/20/15 01:38 PM
08/20/15 01:38 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
That's a fact...
Got over 20 years on a B/C spray...
It's doing fine...
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895901
08/20/15 01:41 PM
08/20/15 01:41 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
flat black would kill any residual value the truck may have IMO. Here's another option for you; my daughter has a 1999 Saturn SC2 which, as you can guess, isn't exactly a high dollar car so repainting it was out of the question.....still, the paint was decent except for some clear that peeled off the decklid and spoiler and a bunch of scratches she put on it with SOS pads trying to remove the stickers....kids.
Anyhow, I took it to a detailer that does work for all the local dealerships and he removed the decals and applied a "Shine-A-Rama" clearcoat....which is some sort of hand applied clear and buffing process. Car looks GREAT. total cost? $574.00
...after seeing the results, one of my trucks (the 2003 Ram) is down getting the same thing done. I'm sure it's "soft" compared to the factory clear but even if I had to do it every 2 or 3 years, it's cheap compared to a $10k+ paintjob.
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895902
08/20/15 01:42 PM
08/20/15 01:42 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
one of my friends does the john deere satin black equipment paint---cheaper than the hot rod black and the satin looks better....
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895910
08/20/15 02:00 PM
08/20/15 02:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
drive as is, save the cash
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895917
08/20/15 02:13 PM
08/20/15 02:13 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
It is a 20 to 50 footer and who is really going to cut you up for owning a truck. The more it peels the less people will park close to you putting in more dents and dings, they will be think this guy is a cowboy and I an not parking next to him. One other way is to wrap the truck. Then you could put a FM3 wrap on your truck with FC7, FJ5 stripes, I like to see you in that Mr. Johnny.
1971 HEMI E BODY REGISTRY
Re: Peeling clearcoat fix ? [Re: Scott Carl] #1895929
08/20/15 02:33 PM
08/20/15 02:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Scott
whatever suits your fancy; poor quality materials and marginal prep will result in peeling no matter if you use bc/cc or if you use single stage. Use the same "cheapest available paint that lasts long enough to get out of warranty period" and the same "fastest prep possible...we got 2000 cars to paint today" prep methods, and your coveted single stage will peel too. thumbs
**Photobucket sucks**
Re: Peeling clearcoat fix ? [Re: DPelletier] #1895941
08/20/15 02:51 PM
08/20/15 02:51 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Cheers,
I only paid $3500 for it so I'm not to worried about the residual value ;), it's got 325k on it.
I'll look into that, it'll bug me after a while and I don't want to make it look too nice , just all the same shades of color.
I'll have my painter friend look at it and see what he thinks.
I looked in that, it looks like that is something special in your area only ?
Re: Peeling clearcoat fix ? [Re: JohnRR] #1895979
08/20/15 03:38 PM
08/20/15 03:38 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I like the color that is on your truck right now, but I am partial to maroon shades. My '64 Polara was close to that from the factory and was repainted with a GM color called "Clementine Metallic" before I bought it.
Anyway, I remember someone telling me years ago "when you buy a new truck the first thing you do is take a fistful of nails in your hand, stick it in the paint and walk all the way around the truck and then you never give the paint another thought". But then, I was born in Montana and there your truck earns it's keep.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Peeling clearcoat fix ? [Re: 70Cuda383] #1896208
08/20/15 09:51 PM
08/20/15 09:51 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Scott
Point taken wink I agree on the prep work for sure, and while I have never painted a car, (rattled canned a couple bikes) I know you get what you pay for in paint. Just seems the factory(s) really dropped the ball there for a while. Hopefully they have found the error of their ways
BTW, Good looking truck, John! beer
Re: Peeling clearcoat fix ? [Re: JohnRR] #1896283
08/20/15 11:39 PM
08/20/15 11:39 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
What were the years they switched to water-based paints? I know Neons were painted with this & the stuff was pure garbage. Everything peeled on them after a few years.
Re: Peeling clearcoat fix ? [Re: Sunroofcuda] #1896389
08/21/15 08:22 AM
08/21/15 08:22 AM
Water based paints are perfectly fine. The vast majority of collision repair facilities are using them now, too, not just the OEMs. Any OEM finishes that were peeling were a result of that particular paint supplier, the OEM's prep/refinishing process and equipment, or both. It has nothing to do with base/clear vs. single stage, waterborne vs. solventborne, etc.... GM and Chrysler's delamination issues predate the introduction of waterborne paint by several years.
DBAP
