71 B Body BB/727 driveshaft length
#1894404
08/18/15 02:40 PM
08/18/15 02:40 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Anybody have or know where to look? I'd like to find the OEM dimension for this shaft? TIA! ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
Re: 71 B Body BB/727 driveshaft length
[Re: 76Beeper]
#1895443
08/19/15 04:42 PM
08/19/15 04:42 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Same length as long as it has the 7290 u-joint.
[Re: 76Beeper]
#1896044
08/20/15 05:45 PM
08/20/15 05:45 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Sorry, I only have the Dodge Manual, but my "best guess" is that they would be the same dimensions as for a '71 Charger. The bodies (panels, sheet metal) are of course a bit different, but would think the underlying chassis' should be pretty close to identical. Maybe you could start a New post asking if '71 RR and Charger Chassis' are identical? I pulled the A727 trans, 8 3/4 rear and HD Leaf Springs from a '71 Road Runner that was (sadly) located at a Pick-A-Part junkyard around 2003. Would have been a restorable car, as most everything was still there and a no rust, California car, when it was sent there for parting out. I saw the hood off it at a swap meet a month or so later. It was yellow.
