Re: Who's the go to for /6 motors?
[Re: stinger]
#1894214
08/18/15 09:48 AM
08/18/15 09:48 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
or go with a 4.0 setup from a jeep? I think this is a very good idea.
[Re: donscuda]
#1894375
08/18/15 02:06 PM
08/18/15 02:06 PM
dogdays
The first name that comes to mind is Doug Dutra. Website that comes to mind is www.slantsix.org, as suggested above by Blazin' Bob. R.
[Re: McCandlessboy]
#1894494
08/18/15 03:56 PM
08/18/15 03:56 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Make sure you have enough room lengthwise, a Slant is longer than a smallblock.
I traded messages with Doug this week. He is in the middle of building a new house and shop and will not have time to do any motors for a while.
Mike Jeffrey in Lexington, NE is THE go to guy for Slants. He does motors when racing and farming are done.
Ron Hamby in NC may do motors. He's a bad man with a Slant too.
[Re: rapom]
#1895349
08/19/15 02:08 PM
08/19/15 02:08 PM
dogdays
Here's the deal...No matter what the weight is, the Slant 6 is not going to fit in that long narrow engine compartment. It's also not the best engine for the car. Here's why.....
As far back as the '20s, the Nash was a big car. It was powered by a decent sized overhead valve six. I believe the architecture of this six was carried over into the '50s. I will try to attach a picture of the engine, maybe two. The '50 Nash engine was 234 cubic inches.
As the car manufacturers thinned out, Nash became part of American Motors and I wouldn't be surprised to find that the Rambler six that we knew in the 1970s as the AMC 232 and the 258 were somehow related to the original Nash 6. They were available in AMC cars with a Torqueflite.
When Jeep was purchased by AMC the weird assembly of engines Jeep had been using were phased out and AMC engines were used to replace them. The last gasp for the AMC 258 six was the 4 liter 6 and 2.5 liter 4. The cylinder head from the 258 was redesigned and is much higher performance than the 258. The crowning touch came when the 4.0 was given fuel injection. There are hundreds of thousands of these engines running around and many if not most of them are bolted to Torqueflites.
Along the way, the crank from the 258 was used in the 4.0 for a stroker by the aftermarket and us hotrodders.
To my way of thinking the fuel injected 4.0 or its stroker variant is what belongs in the car, because of its heritage. Also weighing in on the 4.0s side is the configuration, the rock-solid durability of the engine, the wide availability of parts if any are ever needed, and the fact that it looks a lot like the original engine.
If you want carburetion, the 258 is out there in the same physical package.
R.
[Re: rapom]
#1895365
08/19/15 02:31 PM
08/19/15 02:31 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Correct me if I'm wrong but isn't your car small and light. Slant six's have a big weight problem as they were originally supposed to be aluminum blocks. Production problems made them switch to cast iron which makes them heavy but durable. I also think the 4.0 would be a better choice. The problem with aluminum blockes is the open deck. The cylinders are floating free at the top. That lets them move around and pop head gaskets. I've often wondered about picking one up and welding plates between the top of the cylinder and the block. A quick clean up bore and deck should have it ready to go. Might be able to make some power after that.
[Re: dogdays]
#1895472
08/19/15 05:42 PM
08/19/15 05:42 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
The Slant6 lasted so long because it couldn't make enough power to hurt itself. Sorry, but true.
R.
Sometimes the truth hurts...
...FAFO...
