Well, the wagon got towed!! Time to upgrade the 400!!
#1894089
08/18/15 12:51 AM
08/18/15 12:51 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Well, she overheated on the way to Wally World (Cedar Point) with 8 of us stranded. Overheated, pulled over to a shop off of Baumhart Rd. Steam out of the overflow and rear of the engine. Saw clean oil and antifreeze on the ground. Cooled a little, then took off the upper rad hose to check on thermostat. It was open..HMM.. Luckily I bought a 73 Chrysler 440 radiator to replace the wimpy aftermarket that was in there. I think checking the valve seats and springs are my main concern. Plus, get everything painted, and try to figure out why this Edelbrock AVS Thunder 650 is leaking fuel after shut down. Any thoughts? Putting in Cometic head gaskets. Everything is a stock OE 73 400HP.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Well, the wagon got towed!! Time to upgrade the 400!!
[Re: sunroofgtx]
#1894364
08/18/15 01:57 PM
08/18/15 01:57 PM
Posts: 20,039 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Rick, that carb is brand new. Has maybe 500 miles on it, including your trip to C-bus. I got it at Summit. Receipt is with the info I gave you. If you need me to try to return it, let me know.
Did it warp the heads or damage anything else?
Earning every penny of that moderator paycheck.
DBAP
[Re: sunroofgtx]
#1894451
08/18/15 03:16 PM
08/18/15 03:16 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
Rare to just blow a head gasket on a stock low po mill. Did this get built or was a factory build? Seems odd and i dont think just throwing new head gaskets in there is a great idea.
I want my fair share
[Re: SomeCarGuy]
#1894477
08/18/15 03:37 PM
08/18/15 03:37 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It likely popped the gasket due to the overheat, not the other way around.
[Re: sunroofgtx]
#1894483
08/18/15 03:45 PM
08/18/15 03:45 PM
sunroofgtx
Cleveland
Feets, I agree. the steam was amazing coming out of this thing. Roadhazard, call me.
[Re: sunroofgtx]
#1894489
08/18/15 03:49 PM
08/18/15 03:49 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
For the fuel issue, check the float levels. They may be a touch high.
[Re: sunroofgtx]
#1894511
08/18/15 04:18 PM
08/18/15 04:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
IF it overheated then it's likely the fuel in the carb boiled out due to the overheat.
[Re: sunroofgtx]
#1894573
08/18/15 05:33 PM
08/18/15 05:33 PM
sunroofgtx
Cleveland
Super, the carb has been doing this since new. I'll get on those floats. Thanks a ton.
[Re: sunroofgtx]
#1895105
08/19/15 02:41 AM
08/19/15 02:41 AM
RapidRobert
on the flooding I'd opinionate, too high of psi, as you know eddys dont tolerate much & some OE mech pumps put out a surprisingly high number OR some dirt held the floats open (need a good name brand high flow 10 micron filter right at the carb inlet), Russell etc
[Re: not_a_charger]
#1895195
08/19/15 09:57 AM
08/19/15 09:57 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Was working on my father in laws 69 mustang before summer. new carb. after idling 10 seconds, fuel was pouring out the boosters in the back. float was stuck down and overfilled. make sure that's not your problem. and as mentioned, too high of float levels can also cause the problem, in that it's ok while driving because fuel is being consumed and it stays relatively cool, but there is not much room to expand as it heat soaks after shut down, and can push past the boosters and drip down the venturis
good luck on the rest of it!
**Photobucket sucks**
[Re: sunroofgtx]
#1895205
08/19/15 10:30 AM
08/19/15 10:30 AM
sunroofgtx
Cleveland
I will find out today going to be digging in. Will it be obvious if the head gasket was leaking
[Re: sunroofgtx]
#1895331
08/19/15 01:45 PM
08/19/15 01:45 PM
RapidRobert
I will find out today going to be digging in. Will it be obvious if the head gasket was leaking If you have an emissions testing station in your area they could stick the probe into the air space above the coolant in the radiator neck and any hydrocarbons (from a HG leaking) will immed show up on their meter. with the eng good and hot it take em 5 minutes. & there's other ways to diagnose the HG
[Re: RapidRobert]
#1895428
08/19/15 04:04 PM
08/19/15 04:04 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I will find out today going to be digging in. Will it be obvious if the head gasket was leaking If you have an emissions testing station in your area they could stick the probe into the air space above the coolant in the radiator neck and any hydrocarbons (from a HG leaking) will immed show up on their meter. with the eng good and hot it take em 5 minutes. & there's other ways to diagnose the HG There is a test kit for diesels for this too. Cummins N14 and Cat 3406 had head gasket issues from time to time and there was IIRC a test strip that would detect HC in the coolant. Kevin
[Re: Twostick]
#1895430
08/19/15 04:14 PM
08/19/15 04:14 PM
RapidRobert
Kevin that'd be even easier. Call your diesel shops. I'm assuming it ain't so bad to where it is obviously boiling coolant out. You could pull the stat/stat housing/fanbelt & fill the coolant to the brim of the neck & start it & gun it & see if there's any bubbles or water starts to rise. As you know you only have several minutes that it will tolerate this with no circulation but if there is a HG prob something will happen pretty quickly cuz it is a dead calm (no pumping) & only combustion pressure could make it agitate
[Re: sunroofgtx]
#1895448
08/19/15 04:46 PM
08/19/15 04:46 PM
Posts: 75,102 A Banana Republic near you.
JohnRR
Super, the carb has been doing this since new. I'll get on those floats. Thanks a ton. typical for that carb on an iron, or alum intake, that does, or does not, have the heat crossover blocked. best is to switch to a Holley ... can't believe I said that
[Re: JohnRR]
#1895500
08/19/15 06:26 PM
08/19/15 06:26 PM
feets
Senior Management
Senior Management
Irving, TX
Super, the carb has been doing this since new. I'll get on those floats. Thanks a ton. typical for that carb on an iron, or alum intake, that does, or does not, have the heat crossover blocked. best is to switch to a Holley ... can't believe I said that Mine doesn't do that on an iron intake in Texas heat. I use a 1/4" insulated spacer.
[Re: feets]
#1895620
08/19/15 09:49 PM
08/19/15 09:49 PM
Posts: 2,601 Great White North
Furyman
Great White North
The last two Edelbrocks we have installed flooded right from the get go.Reset float levels,both carbs had casting flash/junk in them.Phoned the tech line ,they say max fuel pump pressure that they can handle is 5 psi which is what a stock 318 pump puts out. Put on a greasy 100k mile AVS on..no issues.I think the quality has taken a big dump on these carbs in the last 6 months or so...never had issues before.
"Long Live Mopars"
