Re: Setting valve lash at base circle with EOIC, weird result??
[Re: RT540]
#1893626
08/17/15 04:17 PM
08/17/15 04:17 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I think you need a trip to Las Vegas but hey that's just me No fishing but plenty of fish to eat, some of the best restaurants in the world here. Sorry for the plug now back to your regularly scheduled post
[Re: RT540]
#1893628
08/17/15 04:18 PM
08/17/15 04:18 PM
Al_Alguire
Las Vegas
Oh yeah there is a TON of flex on a std size cam core at 900lbs..It is exponential from 600 to 900
[Re: RT540]
#1893854
08/17/15 08:49 PM
08/17/15 08:49 PM
Posts: 137 Daytona Beach, FL
cknight
Daytona Beach, FL
Lets say you have 900pounds full lift and maybe 550-600 at half lift an still have a 002 differens, I would think that the force at half lift will have the cam at the same excentric place wiith zero clearance. And that the cam core do flex between bearings. Yes, flex is an issue. When rotated 720 degrees, the cam should be located in the same eccentric position as before. I was referring to the comment on the base circle dip (or "lash increase")as the engine is being turned over. You can see similar results with 300 pounds open, where flex is lees of a factor. Regards, Chase
[Re: cknight]
#1894145
08/18/15 02:26 AM
08/18/15 02:26 AM
Posts: 576 Texas
ChevyTS
Texas
I sympathize with the tech line guys. I'm sure they answer a million simple questions a week. I would think that they would look forward to a difficult problem once in a while. Comp tech guys should have known that I was describing lateral cam deflection. My question to them was " is the cam lobe ground to increase lash a few degrees before the valve starts to open". After I thought about the problem for a while it made perfect sense to me. Now the big question! What can I do about it? I guess we have to say thank goodness for Moparts tech forum. Flex can be an issue, but with conventional cam bearings, you may have .0015" to .0025" cam to bearing clearance. This causes the camshaft to "rattle" around while being turned over slowly, due to the pressure exerted by each of the open valves. Depending on the particular journal clearance and rocker ratio, this can change the lash from .002" to .004". This is what usually causes the apparent dip in the lobe's base circle when checking an assembled engine. Regards, Chase Thank you for your reply. With the intake off of the engine today, I rotated the cam until the intake lobe was 180 degree from the lifter and checked the lash. Exactly .009 Then I rotated the engine until the exhaust valve was almost full lift and could see that the intake was still on the base circle (at this point I guess) and checked again. .029 Using a dial indicator I checked rocker shaft flex and found .006 ish . I indicated off of the cam between the lobes and found about .002 flex. Even taking the 1.7 ratio into consideration I still can't see where the extra lash is coming from.
T & K Performance
[Re: RT540]
#1894664
08/18/15 07:10 PM
08/18/15 07:10 PM
Al_Alguire
Las Vegas
Typical common shaft Dodge stuff. Been trying to tell ya Kinda why we don't run them(any common shaft set up)on serious stuff. Also think some are way overthinking some of this. This is nothing new and is an issue with common shaft rocker set ups. Now try it with a set of Crane gold shafts
[Re: RT540]
#1894921
08/18/15 11:06 PM
08/18/15 11:06 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Are just assuming the cam companies have no idea about this valve train flex and do not account for it in the lash numbers? I would ASSume they know about, and they recommend what they do for a good reason.
68 Barracuda Formula S 340
[Re: camastomcat]
#1895085
08/19/15 01:57 AM
08/19/15 01:57 AM
Posts: 576 Texas
ChevyTS
Texas
I ran B1's for 13 years. Once everything was right, I didn't have anymore valve train issues. I'm not sure why you are having these issues, and to be honest, I never checked intake valve lash with the exhaust at high lift. I ran the single shaft T&D rockers, Koffel black rockers, and common shaft T&D rockers. Never broke a rocker. I also cycled them out after 500 or so runs. You might try calling a long time custom cam grinder like Ken Heard. He owns Oregon Cam, and has been grinding custom cams for me for the last few years. www.oregoncamshaft.com Thanks for the information. I will give him a call. We haven't broken a T&D rocker yet and I want to keep it that way.
T & K Performance
[Re: RT540]
#1895118
08/19/15 03:52 AM
08/19/15 03:52 AM
Al_Alguire
Las Vegas
I have never broken a B1 rocker either. Common shaft or paired shaft. Key is to use the right parts for the job. Most Mopar guys don't wanna spend the money to go fast and step up to better pieces for what they are trying to do. Then they wonder why someone's combo runs better than theirs does. Just my .02
