Power Steering pump boiling?
#1892463
08/15/15 04:05 PM
08/15/15 04:05 PM
Posts: 4,254 Canada
WO23Coronet
Canada
My new to me '67 Coronet with a '77 440 is doing something weird (to me anyway, maybe it's common). After awhile driving, it starts pushing all the power steering fluid out of the pump reservoir fill hole. Appears as if it's boiling it, as it's very hot and frothy and literally boils out. The steering box is pretty worn, on the to do list is to adjust the screw on the top as it's pretty loose (I know its a band aid and I'll eventually replace it) and the valve at the top needs to be adjusted as it turns itself to the right. Is the pump shot or is it continually being worked by the out of adjustment steering chuck?
Re: Power Steering pump boiling?
[Re: WO23Coronet]
#1892632
08/15/15 09:52 PM
08/15/15 09:52 PM
Posts: 5,783 ohio
ruderunner
ohio
Yes it's being worked by the out of adjustment box.
Angry white pureblood male
[Re: joelson6]
#1892796
08/16/15 02:39 AM
08/16/15 02:39 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Check for any blockages in the lines..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: WO23Coronet]
#1892846
08/16/15 09:53 AM
08/16/15 09:53 AM
Posts: 7,664 IN
ahy
IN
Thx for the reply guys, I figured that had something to do with it. Any good info/links on how to properly adjust it? The Factory Service Manual has the procedure if you can get one (good idea anyhow, MoparManuals.com). Its been posted a few times but I've never done one. Basically you slightly loosen the block and tap it left/ right with wheels in the air and engine running until you find the point it stays centered and tighten it down. A power steering cooler would help keep things cool and prevent boiling also... but need to get the box healthy first.
[Re: WO23Coronet]
#1893100
08/16/15 06:54 PM
08/16/15 06:54 PM
Posts: 5,783 ohio
ruderunner
ohio
OK but with the assist valve out of adjustment, the pump is constantly trying to build pressure. Building pressure builds heat.
With the assist valve centered, the pump merely circutales fluid and stays cool.
