Re: Lower valve spring pressure-what rev limit?
[Re: MikeN]
#1890507
08/12/15 08:24 PM
08/12/15 08:24 PM
Posts: 5,886 ohio
ruderunner
ohio
Power reduction and odd intake noises for sure. Mechanical mayhem possibly. But, after proper break in why not run the correct springs? An additive or diesel grade oil should prevent future problems.
For cheap brewak in springs you could use old big block wedge springs.
Angry white pureblood male
[Re: MikeN]
#1890807
08/13/15 04:18 AM
08/13/15 04:18 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Do you have access to a god valve spring tester? If so see what your current springs have and see if you can shim them to get between 120 to 140 lbs on the seats and from 310 to 350 lbs open I would run those I race several different 426 Hemi motors in NHRA stock with the stock hydraulic lifters and new valve springs back in the mid 1970s, both motors would pull hard to 7000 RPM according to the old Sun electric tachs and a Jones Motorola mechanical tach I put in my 1970 Cuda back then We ran cheater cams from the original Racer Brown and Clay Smith cam companys Use a ZDDP additive and break the cam in properly and go have some fun BTW, you may want to check the lift at the retainers on all of your valves, I found out that the stock rocker arm ratio where not very good, they varied horribly IHTHs
[Re: MikeN]
#1891548
08/14/15 01:56 AM
08/14/15 01:56 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Is it hard to get good oil there? If you can source the stuff we run in the US, plenty of guys here run the matching springs with no oil related issues. Either that or opt for a roller cam and get the best of both reliability and power. A hemi with weak springs is like taking the girl home early on prom night.
I want my fair share
