99 Ram 5.2 Magnum rough idle #1889996
08/12/15 01:05 AM
08/12/15 01:05 AM
Stuart, FL
Grassosgarage Offline OP
Stuart, FL
I picked up a '99 4x4 with a 5.2. It had been sitting a long time but fired up running rough. Replaced plugs, wires, cap, rotor, and had injectors cleaned. Truck runs much better but still a rough idle feels like a dead miss but runs well at higher rpm. Suggestions for troubleshooting ?
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890003
08/12/15 01:11 AM
08/12/15 01:11 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you have access to a scanner watch for misfire.
Check for miss the old way, unplug plug wires one at a time.
Compression test
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890125
08/12/15 10:16 AM
08/12/15 10:16 AM
md
mopars4ever Offline
mopars4ever  Offline
md
possible intake plenum gasket leak, look in intake for signs of oil
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890210
08/12/15 12:48 PM
08/12/15 12:48 PM
Stuart, FL
Stuart, FL
I've read about the plenum leak but don't understand that causing a dead miss. What about the idle air control?
'70 Cuda 440/auto
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890290
08/12/15 03:00 PM
08/12/15 03:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Try some throttle body cleaner.
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890740
08/13/15 01:03 AM
08/13/15 01:03 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Bad gas? Battery low? Maybe pull the iac motor and clean everything up in there.
Re: 99 Ram 5.2 Magnum rough idle [Re: Grassosgarage] #1890949
08/13/15 12:45 PM
08/13/15 12:45 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Can you smell gas under the hood? Bad injector seals will cause that symptom...
