99 Ram 5.2 Magnum rough idle
#1889996
08/12/15 01:05 AM
08/12/15 01:05 AM
Posts: 664 Stuart, FL
Grassosgarage
Stuart, FL
I picked up a '99 4x4 with a 5.2. It had been sitting a long time but fired up running rough. Replaced plugs, wires, cap, rotor, and had injectors cleaned. Truck runs much better but still a rough idle feels like a dead miss but runs well at higher rpm. Suggestions for troubleshooting ?
'70 Cuda 440/auto '70 Duster 340/4sp project '70 Satellite convert 318 survivor
Re: 99 Ram 5.2 Magnum rough idle
[Re: Grassosgarage]
#1890003
08/12/15 01:11 AM
08/12/15 01:11 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you have access to a scanner watch for misfire.
Check for miss the old way, unplug plug wires one at a time.
Compression test
[Re: Grassosgarage]
#1890210
08/12/15 12:48 PM
08/12/15 12:48 PM
Grassosgarage
Stuart, FL
I've read about the plenum leak but don't understand that causing a dead miss. What about the idle air control?
