Re: 383 block question!
[Re: Wicked49670dart]
#1890038
08/12/15 02:15 AM
08/12/15 02:15 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only one that is significantly better is the really late 71 block that actually used the 400 thick web block without being bored to 400 bore size. Other than that and the early RB 383 (JUNK) they are all the same.
#1891599
08/14/15 04:51 AM
08/14/15 04:51 AM
Posts: 43,332 Bend,OR USA
Cab_Burge
Absolutely, you may be able to buy a shelf piston from KB, Probe, Ross or SRP also ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#1891666
08/14/15 10:08 AM
08/14/15 10:08 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
I would look for a 400 block and use it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Forget that thin main web 383 ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) The much bigger bore of the 400 block will definitely make more power.
