Re: Indy 360-1 lift loss?
[Re: justinp61]
#1889580
08/11/15 04:45 PM
08/11/15 04:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I broke in my solid cam yesterday and will probable put the inner springs in tonight. If I get a chance I will throw a dial indicator on a rocker and check it for you.
[Re: justinp61]
#1889803
08/11/15 09:50 PM
08/11/15 09:50 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
Wow, .073" and .067" loss! I guessed it maybe .040". Today I had Dwayne Porter order my cam. It looks like I'll need 1.7 rockers instead of 1.65s.
Pittsburg, if you don't mind checking I'd appreciate it.
[Re: justinp61]
#1889894
08/11/15 11:04 PM
08/11/15 11:04 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am not completely sure but on my 360-2 's with 1.65 T&D I think mine went from .704 down to .68x something.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: justinp61]
#1889897
08/11/15 11:09 PM
08/11/15 11:09 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pittsburg, if you don't mind checking I'd appreciate it. . Had to work on the car trailer tonight so I can pick up my duster tomorrow morning so it will be tomorrow now
[Re: justinp61]
#1891502
08/14/15 12:57 AM
08/14/15 12:57 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anyone ever measured the actual lift loss due to the push rod angles with Indy 360 heads?
Thanks Justin I'm sorry but I tried to get some good measurements for you but with the engine in the car I would have had to make up a plate to hold the mag base steady and just didn't have the time. I finished the tune and have the car loaded for testing tomorrow at PRP.
[Re: justinp61]
#1891532
08/14/15 01:31 AM
08/14/15 01:31 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't like these rocker adjusters (indy rockers) so I will probably be back inside the covers real soon.
