Ready to run distributors ???? #188911
01/09/09 10:04 PM
01/09/09 10:04 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Anyone know what this means?
I was looking for a distibutor on Ebay
and this popped up on several auctions.
Re: Ready to run distributors ???? [Re: BADBEE] #188912
01/09/09 10:10 PM
01/09/09 10:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Think it means they have some sort of ignition module built into them
Re: Ready to run distributors ???? [Re: BADBEE] #188913
01/09/09 10:12 PM
01/09/09 10:12 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
That means that you dont need any other addititonal ignition box,it is all contained in the distributor.
Re: Ready to run distributors ???? [Re: coro500net] #188914
01/10/09 01:28 AM
01/10/09 01:28 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
ECU is built in, ie you do not run a chrome box, orange box, etc. Two wire hookup usually. One wire to power, one to coil if memory serves. The one I used to have ran a hall effect sensor instead of an old school magnetic pickup, supposed to deliver more accurate spark timing. One thing I wonder about them is how easy/hard they are to adjust the advance curve.
Re: Ready to run distributors ???? [Re: BADBEE] #188915
01/10/09 04:11 AM
01/10/09 04:11 AM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
I just bought one from wysco, I plugged in and it ran great. One wire to ignition pickup, then the ground and coil wire (external coil). The problem I have no is retracing all the old wires and [Edited by Moparts - Keep it clean], since alot of the factory wire bundles have the alt, and distributor harnesses taped together.
It's made for a full day so far.
Re: Ready to run distributors ???? [Re: RoyceFlo73] #188916
01/10/09 05:14 AM
01/10/09 05:14 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
I posted on here a while ago that I installed the same one on my '85 Gran Fury (I know, not a muscle car) but it was so easy, the results are instant and you can really feel how much better it runs plus its all self contained so a little extra work and a lot wiring goes away.
Re: Ready to run distributors ???? [Re: DaytonaTurbo] #188917
01/10/09 09:07 AM
01/10/09 09:07 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I haven't seen a ready to run that didn't have an adjustable advance.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Ready to run distributors ???? [Re: dgc333] #188918
01/10/09 01:42 PM
01/10/09 01:42 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
It's easy to set various mechanical advance settings. Has vacuum advance, good for highway driving. It is a high quality piece. I've ran one now for a few years without any problems whatsoever. Easy to install.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Ready to run distributors ???? [Re: Junky] #188919
01/10/09 06:10 PM
01/10/09 06:10 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
How difficult are they to recurve the Mech advance? will they work with a performance set up and a super coil or msd blaster w/o a ballast? what about the module? are they easy to replace and obtain? can the dist caps be swapped for and original type mopar cap?
Re: Ready to run distributors ???? [Re: Dakota_Don] #188920
01/11/09 12:05 PM
01/11/09 12:05 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
See reply to your PM.
Re: Ready to run distributors ???? [Re: BADBEE] #188921
01/12/09 10:03 PM
01/12/09 10:03 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I've had the MSD digital "E" curve all in one SB Dist for 18? months. It also has a VA port. It has many built in switch selectable curves for Mech and VA. It also has a rev limiter. I like it.
