intake manifold thermal barrier coating...?? #1888228
08/09/15 07:47 PM
08/09/15 07:47 PM
jersey
Spaceman Spiff Offline OP
jersey
Anyone have a thermal barrier coating applied to their intake?
Who did you use, and how were the results?
Thanks! up
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: intake manifold thermal barrier coating...?? [Re: Spaceman Spiff] #1888270
08/09/15 09:08 PM
08/09/15 09:08 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Bud Yancer did mine, It is coated inside and out. My motor seems to like a annular booster carb over a down leg, the only reason I can think of is because the intake runs so much cooler it likes the smaller droplets of fuel.
Re: intake manifold thermal barrier coating...?? [Re: Darryls-Demon] #1888285
08/09/15 09:30 PM
08/09/15 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like it would be great with injection
wave
Re: intake manifold thermal barrier coating...?? [Re: MR_P_BODY] #1888987
08/10/15 06:44 PM
08/10/15 06:44 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I didn't do my intake but I did my Combustion Chambers, valve faces and exhaust stems and ports which should (residually) keep the heads and intake temperatures down by passing more heat to the exhaust.
Only did a break-in on it so far, I'll keep you posted once the car is running around.
WIZE
In Car:
Re: intake manifold thermal barrier coating...?? [Re: Spaceman Spiff] #1889819
08/11/15 09:58 PM
08/11/15 09:58 PM
jersey
jersey
If the weather is nice this weekend, i'll take some temp readings of the intake, at various points and note them.
This isn't a racecar, so i'm not looking to do this for max performance. it's a street car that gets driven A LOT. so i'm trying to keep under hood temps down, prevent any vaopr lock issues, and have a cooler and better running engine in the summer months.
I was also thinking of using a ram air box type set up, but i'd rather not cut holes in my core support.
Re: intake manifold thermal barrier coating...?? [Re: Spaceman Spiff] #1889989
08/12/15 01:02 AM
08/12/15 01:02 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Good luck with that. I think you're going to be disappointed with the results. What the barriers keep out they also hold in. Once the manifold gets heat soaked (and it will on a street car!) its going to stay that way much longer. You want to reduce under hood temps, move more air through it.
Re: intake manifold thermal barrier coating...?? [Re: Stanton] #1890744
08/13/15 01:07 AM
08/13/15 01:07 AM
Glendale Az
Glendale Az
This is not what I have found with my intake, my intake seems to run so cool that when I ran a down leg booster carb the fuel would puddle in the intake at an idle. I had to switch to a annular booster carb.
david vizard rote an article on this subject a few years ago and seems to have found the same thing. The testing he did was for a nascar team.
Re: intake manifold thermal barrier coating...?? [Re: Darryls-Demon] #1891031
08/13/15 02:49 PM
08/13/15 02:49 PM
dogdays Offline
dogdays  Offline
Mr. Stanton forgets that when the engine is running, there is a large quantity of cooler outside air rushing through the intake, and usually there are fuel droplets evaporating, and that change of phase requires energy.
The thermal barrier is really just a layer of insulation that reduces heat flow, and heat always flows from hotter to cooler temperature. The barrier on the outside reduces heat flow from the hot oil splashing onto the underside of the intake, and the barrier inside slows the heat that migrates up from the cylinder head face. Barrier on top of the intake slows underhood heat, and some can get quite warm.
If the phase change requires more energy than is conducted by the manifold, the interior temperature will decrease below incoming air temperature.
Edelbrock makes its prototype intake manifolds out of fiberglas. The material has a lower thermal conductivity than aluminum. Because of this, the prototype intakes are always more powerful than the aluminum production intakes. I'd be interested in a ceramic intake. Posed this suggestion to Edelbrock years ago and their response was "We have our own foundry."
Now we have moved into space-age plastics.
R.
Re: intake manifold thermal barrier coating...?? [Re: Spaceman Spiff] #1891135
08/13/15 05:25 PM
08/13/15 05:25 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What would you port a ceramic intake with ???
Re: intake manifold thermal barrier coating...?? [Re: Stanton] #1892008
08/14/15 07:43 PM
08/14/15 07:43 PM
dogdays Offline
dogdays  Offline
Hanged if I know, but as 99% of the intakes that Edelbrock sells are NOT ported, maybe the question itself has little relevance.
Have a nice day,
R.
Re: intake manifold thermal barrier coating...?? [Re: Spaceman Spiff] #1892072
08/14/15 09:43 PM
08/14/15 09:43 PM
jersey
jersey
10 mile drive home from work, engine temp at 200° various points on the intake at 170° to 178°.
Exhaust was al over the place tho, from a low of 495° to about 605°
This weekend, I'll take more readings and note their locations.
