lower control arm bushings #188875
01/09/09 09:05 PM
01/09/09 09:05 PM
Arlington Heights, IL
Ovalracer68 Offline OP
what is the proper method of installing new rubber bushings in the lca? ive never had a problem with the polys, but the rubber is giving me trouble this time. i pressed the bushing into the arm, but when pressing in the pivot shaft, it wants to push the rubber and inner sleeve out through the torsion bar end. yes i did remove the old sleeve from the shaft so thats not it. any ideas? thank you.
Re: lower control arm bushings [Re: Ovalracer68] #188876
01/09/09 09:15 PM
01/09/09 09:15 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/index.html
The "shaft" is pressed into the bushing first, then the bushing with the shaft, is pressed into the lower control arm.
The link to the above article is very helpfull.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: lower control arm bushings [Re: hemi71x] #188877
01/09/09 09:28 PM
01/09/09 09:28 PM
thanks!!!
i guess i reversed the order of installation. i'll go try again now.
Re: lower control arm bushings [Re: Ovalracer68] #188878
01/09/09 10:03 PM
01/09/09 10:03 PM
Georgia,Douglasville
streaker Offline
streaker  Offline
thanks!!!
I learned this lesson the hard way just last night. New bushing $15.00
I said Don't look Ethel, It was too late
Re: lower control arm bushings [Re: Ovalracer68] #188879
01/09/09 10:26 PM
01/09/09 10:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You can press in the shaft after you install the bushing in the LCA. You just need to back up the sleeve with a steel or aluminum spacer from the back side of the LCA. I have used a deep socket for this purpose.
Re: lower control arm bushings [Re: Snoopy] #188880
01/09/09 10:34 PM
01/09/09 10:34 PM
If they are real close tossing the shaft in the freezer for 24 hrs to shrink it might help.
Re: lower control arm bushings [Re: RapidRobert] #188881
01/10/09 09:36 AM
01/10/09 09:36 AM
streaker Offline
streaker  Offline
I have now done this both ways and I will never press in the bushing first ever again. The trick is having a piece of pipe that fits on the bushing colar over the pin. Good luck to all.
Re: lower control arm bushings [Re: Snoopy] #188882
01/10/09 10:36 AM
01/10/09 10:36 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I have done this way also
