Re: New 440 for 1979 "300" painted and ready for install.
[Re: qwkmopardan]
#1888464
08/09/15 11:49 PM
08/09/15 11:49 PM
Posts: 7,506 Az
Crizila
Az
Going in this car. Very cool!! What's your ET goal?
Fastest 300
[Re: LaRoy Engines]
#1888523
08/10/15 01:22 AM
08/10/15 01:22 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
Looks pretty. So, after you dyno it, log back in and tell us how close you came to that 707 HP. That should be a record for 587 heads! I'm sure there are not many 440 c.i. sm blocks with 587 heads so I'm traveling through uncharted waters. However the 418 c.i. engine in my Demon has been 9.68 at 136.XX mph. Weighs 3050lbs. Same head castings with a little less flow, with a slightly bigger camshaft and a little more squeeze, but 24 c.i. smaller. 670 +/- HP. 670/418 = 1.603 HP per C.I. Will not put it on a dyno but the car will let me know. The "300" weighs 4000lbs and should put it solid in 10 second zone. 650 hp would make it run 10.70s, 700hp would be 10.40s. We will find out soon enough.
[Re: qwkmopardan]
#1888663
08/10/15 11:25 AM
08/10/15 11:25 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
Looks pretty. So, after you dyno it, log back in and tell us how close you came to that 707 HP. That should be a record for 587 heads! I'm sure there are not many 440 c.i. sm blocks with 587 heads so I'm traveling through uncharted waters. However the 418 c.i. engine in my Demon has been 9.68 at 136.XX mph. Weighs 3050lbs. Same head castings with a little less flow, with a slightly bigger camshaft and a little more squeeze, but 24 c.i. smaller. 670 +/- HP. 670/418 = 1.603 HP per C.I. Will not put it on a dyno but the car will let me know. The "300" weighs 4000lbs and should put it solid in 10 second zone. 650 hp would make it run 10.70s, 700hp would be 10.40s. We will find out soon enough. Well dog-gone-it, I think that is really something. Love it when someone can do that with old iron heads.
[Re: justinp61]
#1888775
08/10/15 02:27 PM
08/10/15 02:27 PM
qwkmopardan
Affton MO
No, not filled. Car will be street driven. What are the holes in the oil passage in the lifter galley on the drivers side of the block? Oil drainback. There is a 3/4" hole in camshaft thrustplate. Hard acceleration oil stays up top, anytime else, oil drains through the old lifter oil galley. Engine in "300" now,[408c.i.] has all the same junk. 20000+ miles, zero problems, Demon , same way, 1900+ passes, no problems.
[Re: Porter67]
#1888786
08/10/15 02:38 PM
08/10/15 02:38 PM
qwkmopardan
Affton MO
Whatever it makes thats a cool build, what do you feel your shift points will be with that cam? Could you explain the lifter valley mods?
Ive seen some heads like those go 290 or so and from my own exp. 420-440 inches might as well be 400 inches as the 420-440 area just cant breath enough, but ive been wrong before.
Nice looking car its going into as well. 6700/6800 shift. I will have to experiment as it may be better lower. Torque should be very good on this engine. Oil control. Hard acceleration oil stays up top, anytime else, oil drains through the old lifter oil galley. Engine in "300" now,[408c.i.] has all the same junk. 20000+ miles, zero problems, Demon , same way, 1900+ passes, no problems. "300" has already been 11.60s at 116mph with a 408 with a lot less porting and camshaft. Engine in car now makes around 525HP.
[Re: qwkmopardan]
#1888867
08/10/15 04:00 PM
08/10/15 04:00 PM
Posts: 7,506 Az
Crizila
Az
Be prepared for wrinkled 1/4 panels near the "B" pillar area unless you do something with the middle of the car ( cage / subframe connectors). You will definitely be in the NHRA mandatory cage range anyway.
Fastest 300
[Re: Crizila]
#1888945
08/10/15 05:48 PM
08/10/15 05:48 PM
qwkmopardan
Affton MO
Be prepared for wrinkled 1/4 panels near the "B" pillar area unless you do something with the middle of the car ( cage / subframe connectors). You will definitely be in the NHRA mandatory cage range anyway. Going for a 6 point roll bar as soon as it runs. Also boxing the leaf spring mounts and connecting frames. Full cage not needed until 9.99 and quicker
[Re: qwkmopardan]
#1889100
08/10/15 10:22 PM
08/10/15 10:22 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
No, not filled. Car will be street driven. What are the holes in the oil passage in the lifter galley on the drivers side of the block? Oil drainback. There is a 3/4" hole in camshaft thrustplate. Hard acceleration oil stays up top, anytime else, oil drains through the old lifter oil galley. Engine in "300" now,[408c.i.] has all the same junk. 20000+ miles, zero problems, Demon , same way, 1900+ passes, no problems. That's what I figured. I'm sure it'll run hard, all your stuff does.
