Mixing Race gas 110 and E85 #1887946
08/09/15 11:26 AM
08/09/15 11:26 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I run the fast ez efi and would like to know if there are any ill effects mixing turbo blue 110 and summer grade e85. Will the mix have any effect on the wide band 02 sensor?
the system I have is e85 compatible.
Thank you
Kiddart
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887958
08/09/15 12:08 PM
08/09/15 12:08 PM
Az
Crizila Offline
Crizila  Offline
Az
I wouldn't do it. Very different fuels with different additive packages - and they all might not be compatible. JMO.
Fastest 300
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887963
08/09/15 12:14 PM
08/09/15 12:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would be better off if you mixed E98... I
just dont know how that 110 mixes with ethanol
wave
Re: Mixing Race gas 110 and E85 [Re: Crizila] #1887965
08/09/15 12:16 PM
08/09/15 12:16 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
how about e85 and 93 octane? I have been told that e85 ranges from 108 to 110 octane? Not sure what is different with turbo blue from 93 octane that's why I am asking these questions.
I do appreciate the replies
Thank you
Kiddart
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887966
08/09/15 12:17 PM
08/09/15 12:17 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
whre do I find e98?
How you feeling Mike?
Thank you
Kiddart
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887970
08/09/15 12:24 PM
08/09/15 12:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Kiddart
whre do I find e98?
Check with your local performance fuel shop as
to where you can get E-98... they may sell it..
the E-85 is suppose to be 105 octane... E-98 is
suppose to be 110 octane.... I'm doing a lot better
wave
Re: Mixing Race gas 110 and E85 [Re: MR_P_BODY] #1887973
08/09/15 12:27 PM
08/09/15 12:27 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
great to hear you are doing better
I will check at Carls custom Concepts on Groesbeck
where you hanging out on Wednesday??
Thank you
Kiddart
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887975
08/09/15 12:33 PM
08/09/15 12:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is there a reason to do this? storage or something? Or are you worried about running out of e85, and needing to refill with straight gas?
As far as finding benefits to doing this, I don't see you finding any. If this is just a "what happens if I have to" question... First, you will have an uncontrolled mixture of fuel of which you have no real clue of it's a/f mixture properties. Whatever target ratio is in your efi table will be out of calibration for the mixture.
Re: Mixing Race gas 110 and E85 [Re: Kiddart] #1887981
08/09/15 12:43 PM
08/09/15 12:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont know... I'm putting the engine/trans back
in today... wont be able to paint until tomorrow
(thats when I can get the booth)... if I go out
there at all I'll be with my buddy in his 52 Ford PU
wave
Re: Mixing Race gas 110 and E85 [Re: TRENDZ] #1887993
08/09/15 12:57 PM
08/09/15 12:57 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
If his EFI system has an input for one of the common GM style flex fuel sensors it wouldn't be an issue. Without the sensor I don't think any of the aftermarket ECU's are smart enough to infer ethanol content and adjust everything accordingly.
