Re: New 383 stroker on the dyno
[Re: AndyF]
#1887337
08/08/15 08:52 AM
08/08/15 08:52 AM
Posts: 1,051 The Great White North
RAMM
Is that an electronically actuated throttle? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: AndyF]
#1887558
08/08/15 05:14 PM
08/08/15 05:14 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I must be missing something or it is very small cam, seems like a 426 or so with RPM heads and a single plane would want to turn a few more RPM than that? TQ does seem good for that cubes though.
[Re: gregsdart]
#1888606
08/10/15 08:39 AM
08/10/15 08:39 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I just recently built a 383 stroker prettysimilar but with 4.25" stroke and a hydraulic flat tppet & RPM intake + 770 street avenger carb. Headers were TTI 1 3/4" primary and 3" exhaust withmufflers. It IS a nice street engine, made 550 ft-lb already at 2500 rpm, peak was 617 ft-lb at 3900, 500 hp was reaiy at 4500 and peak was 518 between 4800 and 5100.
Plynouth VIP '67 TT IC EFI
[Re: 1Fast340]
#1889337
08/11/15 09:23 AM
08/11/15 09:23 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Sweet! But i have to ask about that intakemanifold,is that a Supervictor singleplane on a somewhat low rpm engine? i can see the benefit of the nice straight runners and straight approch into the ports in the cylinderheads but it sure seems alitle out of place on an engine that i thought would have made good use of a nice dualplane considering the fairly low peakhp rpm. Want to hear about the SUPER VICTOR ? It makes suer numbers et me tell you.... A fellow racer here just did a refresh on his 416. He raised compression 1 point to 11.8 The same old ported large port commando heads flat tappet to solid roller cam Going from a M1 intake to a Super Victor fully ported Old numbers: 545 hp 543 lbs tq New numbers: 637 hp 593 lbs tq pretty impressive !! but personally, I don't give much of his old cast crank on the track ! lolll Dan
[Re: AndyF]
#1889362
08/11/15 10:50 AM
08/11/15 10:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Andy.. I assume you spin/start the engine using the dyno itself... and dont need a starter and bell housing
[Re: AndyF]
#1889676
08/11/15 07:11 PM
08/11/15 07:11 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Nice engine, Andy. I agree, the performer RPM sounds like the ticket on this combo, but who are you to argue with a paying customer! I bet the Holley SD would have done well too.
2 kids and a dog
[Re: dogdays]
#1889694
08/11/15 07:46 PM
08/11/15 07:46 PM
Posts: 31,049 Oregon
AndyF
Andy, 4.25 x 3.75 is a 426, 4.28 x 3.75 is a 432. Did you slip in a little extra stroke? this is going off your 450 cubic inch engine comment.
Jyrki, that extra half inch of stroke really made a difference. It's going to be hard to keep tires on that thing.
R. I think this engine is 0.060 over so it is a 438. I'm not positive, it isn't my engine and I didn't build it. I just showed up for the dyno test to help get the new dyno system up and running. This engine shop has a number of Mopar engines in process. Always nice to see that guys are building big blocks.
[Re: TonyS451]
#1889698
08/11/15 07:49 PM
08/11/15 07:49 PM
AndyF
Nice engine, Andy. I agree, the performer RPM sounds like the ticket on this combo, but who are you to argue with a paying customer! I bet the Holley SD would have done well too. Yeah, a Performer RPM witha one inch open spacer would probably make more torque everywhere and equal HP at the top of the curve. But it is hard enough to convince customers to spend the $500 for dyno testing. Trying to talk them into buying a stack of parts and paying for the extra time to test them all is basically impossible. Very few people have a budget for parts testing.
