Advice needed on possible gear swap
#1887058
08/07/15 07:14 PM
08/07/15 07:14 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
340 with w2's, .590 purple, 904 with 5500 Dynamic, 5.13's with a 29" Hoosier. I am considering a switch to 5.38's to see what would happen. Suggestions? My reasoning is to try and compensate a little for not having a low first in the trans. and see about picking up my 60ft. a little (best is a 1.55) trying to get a 10.9? out of this combo at Bandimere altitude. Thank you for the help.
Better get inside Ma. Looks like a storm's comin'.
Re: Advice needed on possible gear swap
[Re: Dartthunder340]
#1887079
08/07/15 07:44 PM
08/07/15 07:44 PM
Dartthunder340
Ron, I am shifting at 76-7800. I hate to say it but not sure where I am trapping at because I am concentrating on driving. I will say the shift light nor Rev limiter come on.
#1887209
08/07/15 11:13 PM
08/07/15 11:13 PM
Dartthunder340
Jbody, I believe I may had had issues with the carb. I have since sent it to Thumpercarbs and am planning on positive results in that department. I am sure the convertor stalls there and it probably has less than 100 passes on it. Not sure how often to have them freshened.
#1887309
08/08/15 03:08 AM
08/08/15 03:08 AM
Dartthunder340
Not exactly sure of the LSA but it installed on a 104*. Heads are w2's that have been ported, but I would prefer to use stock numbers if that info is needed. I bought them used and don't have flow numbers. The lash is set at .25 in/ex cold. I will have to wait until tomorrow to give time slip incremental as I am out of town. 11.55@115 was best pass last year, have not been able to get out yet this year.
