Early B body with 315 60 or 30x12 slick? #1886915
08/07/15 02:20 PM
08/07/15 02:20 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
I have 29.5 10.5w on my 66 Belvedere might go to a 315 as car geared 4.88,
Any other early Bs on here running a 30" tire.
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887063
08/07/15 07:20 PM
08/07/15 07:20 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i ran 325/50's and 28x10.5 slicks my 66 belvedere, we cut the front edge of the fender lip as far forward as we could, i traded my 325's for 315's(for another car)i can try them on the 66 if you need me too but if you already have 29.5's on yours then your there, a 315 is only 29.6" tall
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887071
08/07/15 07:32 PM
08/07/15 07:32 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Randy ,I have my slicks on my D50 right now so you can try my 315/60's and see if they fit. They are on 10 in wheels.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887072
08/07/15 07:34 PM
08/07/15 07:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a 30 x 9 Hoosier radial slick on my 63 and I use 4.30's. But it is a street car I drive all the time on them tires. Ron
Re: Early B body with 315 60 or 30x12 slick? [Re: D-50] #1887259
08/08/15 12:34 AM
08/08/15 12:34 AM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
What the back space on you're wheels Glenn? Would trade these slicks for a fair pair of DRs.
You going to the 256 callout at Moulton sat?
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887456
08/08/15 01:30 PM
08/08/15 01:30 PM
AndyF Offline
AndyF  Offline
I have 325/50-15 drag radials on my '65 Coronet or for street I run a 315/45-17. Width isn't the problem on my car with the mini-tub, but a 30 inch tire would be tough to fit in there.
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887468
08/08/15 01:53 PM
08/08/15 01:53 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
That's what I'm thinking, it's mini tubed and the rear is one inch shorter on each side, got plenty of width, will change over to some 3.54s this fall, just trying to get it the way I want before engine goes back in.
If it wasn't already painted would open up the openings at the front if I had to, I can live with 295s if the 315s won't go,
D50 is gonna let me try his so will know for shure this week anyway.
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887471
08/08/15 02:03 PM
08/08/15 02:03 PM
AndyF Offline
AndyF  Offline
You can use a longer spring hanger to move the axle back a bit but you have to be careful since then you need to double check the driveshaft length as well as shock clearance and gas tank clearance etc.
Re: Early B body with 315 60 or 30x12 slick? [Re: Randy..] #1887488
08/08/15 02:24 PM
08/08/15 02:24 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
It's ladder bar coilovers, have to make shure have enought thread on rod ends,
To be honest think its had some on it before, very bottem of opening has been touched a little.
