Bench bleeding the master #1886261
08/06/15 02:21 PM
08/06/15 02:21 PM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
It has been decades since I have done this.
I have no bubbles coming out in the forward reservoir.
However the rear pot keeps producing a stream of tiny bubbles.
Do I need to continue until it has zero bubbles, or am I seeing a small air leak in the plastic adapter or rubber hose?
Again, thanx for any help.
I have mechanical Aptitude.
I can screw up anything.
Re: Bench bleeding the master [Re: bboogieart] #1886266
08/06/15 02:24 PM
08/06/15 02:24 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
I Just did this on Saturday. It took about 20 minutes of slowly pushing the plunger to get no bubbles in either pot. I would keep at it. twocents
Re: Bench bleeding the master [Re: Charger446] #1886268
08/06/15 02:26 PM
08/06/15 02:26 PM
Lost and Spaced
Lost and Spaced
Thanx,
I guess I was getting impatient.
Not rare for me.
Re: Bench bleeding the master [Re: bboogieart] #1886335
08/06/15 04:18 PM
08/06/15 04:18 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I have had the best luck with mounting the Master on the firewall and slowly bleeding it using the brake pedal and running the bleeder hose back into the reservoir.
Re: Bench bleeding the master [Re: 65pacecar] #1886381
08/06/15 06:08 PM
08/06/15 06:08 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
How can you bench bleed it when it's not on a bench?
Just for giggles, I have been bench bleeding masters on the car since the 60's. Why have to carry a dripping master cylinder over a nicely painted fender?
Re: Bench bleeding the master [Re: John Brown] #1886398
08/06/15 06:39 PM
08/06/15 06:39 PM
Lost and Spaced
Lost and Spaced
It's all said and done. Pedal is high and firm, just like it should be.
Master didn't drip and fender isn't nicely painted.
Thanks again to all that helped.
Re: Bench bleeding the master [Re: bboogieart] #1886630
08/06/15 11:00 PM
08/06/15 11:00 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
I just did mine using the "new" method. steel plugs in both ports and slowly depressed brake pedal (on car) until the pedal firmed up. I was surprised it worked so well..
PLaz
