froze brass fittings...help.
#1886041
08/06/15 12:43 AM
08/06/15 12:43 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
on a fuel line leading into the carbs there is a brass fitting..it screws into another brass fitting on the carb..in order to remove the fuel filters inside these carbs I have to get these two fittings apart..they are locked up like nobodys business..you cant remove the entire fitting as it twists the metal fuel line...I have to get them apart..period!... Cannot heat them as it IS a fuel line..this is on twin big block motors for a boat if ive confused anyone...any suggestions to get a couple brass fittings apart would be greatly appreciated..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: froze brass fittings...help.
[Re: 72N96RR]
#1886052
08/06/15 01:00 AM
08/06/15 01:00 AM
RapidRobert
can you heat up the thread junction with something other than a flame (shop light maybe) & melt some candle wax into the threads or the old standby WD40 applied daily for several days in a row
[Re: 72N96RR]
#1886057
08/06/15 01:11 AM
08/06/15 01:11 AM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
[Re: 72N96RR]
#1886064
08/06/15 01:29 AM
08/06/15 01:29 AM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Tri-flow works better and faster than wd40 for this sort of thing.
You could unbolt the carb and turn it, instead of the fitting...
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1886081
08/06/15 02:03 AM
08/06/15 02:03 AM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Are you using Line Wrenches?
One "trick", sometimes it actually helps to tighten the fittings (which can sometimes break them loose, especially if the fittings are damaged or rounded off a bit), before attempting to loosen/remove the fitting.
Another possibility, you could undue the fuel-line at the fuel pump, and then use two box-end wrenches on the fittings to try to get them apart.
If that doesn't work, hack-saw through the fuel Line, then remove the carb or just the float bowl, then you can work on it at a work-bench with Boxed-End Wrenches, Also, that way you can remove the fuel from the equation and heat the fittings a bit if necessary. I have had to go that route before.
You can also try some PB Blaster. Or, you can soak the fuel bowl with brass fittings, overnight, submerged in penetrant.
[Re: 72N96RR]
#1886417
08/06/15 07:16 PM
08/06/15 07:16 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
As silly as it seems, get the handles of both wrenches within 20 degrees of one another and wrap both hands around the both wrenches. Squeeze them together to break it loose. It sometimes works for me when I'm dealing with something stuck hard.
As stated earlier, if you can't get box end wrenches on there then use line wrenches. Open end stuff is not your friend in this situation.
