Re: W2 Parts Questions [Re: Porter67] #1885655
08/05/15 03:32 PM
08/05/15 03:32 PM
Indiana
Y
YO7_A66 Online content OP
YO7_A66  Online Content OP
Y
Indiana
"" if your looking to stay under 6500 id consider a smaller plenum/runner single plane and a non ported set of castings""
Porter,
You have a nice selection of W2 items! Thank you for sharing the pictures.
This Fall I plan on my search for parts and I was hoping to find a set of the Econo W2's.
What would you suggest as a "smaller plenum/runner single plane"?
If experienced people like you say stick with a certain single plane, then that will be the direction that I go.
Thank you again,
Re: W2 Parts Questions [Re: YO7_A66] #1885692
08/05/15 04:19 PM
08/05/15 04:19 PM
P
Porter67 Offline
Porter67  Offline
P
Opinions vary and I would get as much input as possible like your doing.
Although I have a good selection of parts, there are so so many more experienced then I but when you get that far and want to try the single plane let me know and id probably loan it out for a month or two for testing since the cost of W2 manifolds has went crazy the last 10 years.
Really, older mags that didnt sugar coat things are a good source of W2 builds as well as the older mopar direct connection publications.
Look at this Victor W2, a high rpm intake but awsome.
Re: W2 Parts Questions [Re: YO7_A66] #1885785
08/05/15 06:38 PM
08/05/15 06:38 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Hey Mr. Porter! Thanks for posting the Holley Street Dominator.
(Top pic for those that do not know)
I was trying to do just that.
YO, on a milder cammed, street bound mill, the smaller plenum has an advantage over a larger plenum in throttle response. It is easier to tune the carb. Instead of the runners drawing from a huge plenum first, it can also pull on the carb as well. Since there's less plenum area to draw on. Low rpm operation is easier.
Holley designed the intake this way vs. there strip dominator that has a larger plenum and longer runners. Porters mention of the W2 initial design use is correct. Higher lift, higher rpm. The use of the W2 as cast can still be a very good head. They flow best at high lifts. The low lift suffers a little bit.
I will use my future W2 bowl ported and with a high lift cam. With that street dom intake it will have a snappy response and good upper power. Not a high rpm screamer. Easy, simple, non complicated build.
Re: W2 Parts Questions [Re: YO7_A66] #1885833
08/05/15 08:07 PM
08/05/15 08:07 PM
P
Porter67 Offline
Porter67  Offline
P
Im not one to try to sway on a personal individualistic idea because god knows ive got plenty of my own, but with a 6500 rpm limit a X or J head would make just as much power in and save alot of money and possible grief.
If your 340 is 4.050 or a hair bigger Im sitting on something old school killer that would only appeal to a certain group ( A trick rotating assembly, a 318-3 steel crank at a 3.45 stroke, ect ).
Re: W2 Parts Questions [Re: Porter67] #1886017
08/06/15 12:15 AM
08/06/15 12:15 AM
Indiana
Y
Y
Indiana
Porter,
How much cfm can be made out of a set of ported 2.02" j-heads?
The bowls were blended on mine but never flowed.
Can my existing RPM intake be ported to a set of W2 heads?
Re: W2 Parts Questions [Re: YO7_A66] #1886024
08/06/15 12:20 AM
08/06/15 12:20 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Originally Posted By YO7_A66
Porter,
How much cfm can be made out of a set of ported 2.02" j-heads?...
I know you asked Porter specifically, and I hope he provides more info while I've barely got enough DIY experience to recognize some of the port terminology, but here are some specs on a totally DIY job based on the swirl-port ('308 castings) MP templates.
So my heads are the 596 castings, new Manley severe duty valves, 2.02/1.60, 11/32 stem, new bronze guides, and a standard 3 angle valve job. I ported them using the MP porting templates, here are the flow numbers (flowed on SF-600 @ 28" water):
LIFT I E
0.100 67 57
0.150 99 79
0.200 130 104
0.250 162 125
0.300 189 140
0.350 215 152
0.400 235 160
0.450 253 167
0.500 262 172
0.550 261 175
0.600 248 177
Re: W2 Parts Questions [Re: Diplomat360] #1886146
08/06/15 09:42 AM
08/06/15 09:42 AM
Indiana
Y
Y
Indiana
Nice job Diplomat! I need to see what my 2.02" J-heads can be ported too after seeing your numbers. I think that I need to be in the 250ish range at .550" to get to my goals.
Thank you for posting that information!
Re: W2 Parts Questions [Re: YO7_A66] #1886164
08/06/15 10:32 AM
08/06/15 10:32 AM
P
Porter67 Offline
Porter67  Offline
P
Dip360, them are some good numbers and the temps you used are proven to work. The 11/32 stem helps as well. You could get a hair more but the effort involved imo wouldnt produce the expected returns for the time involved.
Unless set to certain class rules many times its easier just to jump to a better head/casting.
As far as getting a la intake to a W2, alot of work. Best route is to get the intake made for the head.
Re: W2 Parts Questions [Re: YO7_A66] #1886175
08/06/15 11:18 AM
08/06/15 11:18 AM
wisconsin
kmfdm Offline
kmfdm  Offline
wisconsin
I'll have to find my flow sheet for my econo W2's, but with only some mild porting I'm flowing 288cfm on the intake side at .550 lift. I'll check all the specs and post them when I get home tonight.
74 Dart Sport
Re: W2 Parts Questions [Re: kmfdm] #1886253
08/06/15 01:55 PM
08/06/15 01:55 PM
Indiana
Y
Y
Indiana
KMFDM,
Please post the flow numbers when you get a chance. Thank you!
Re: W2 Parts Questions [Re: YO7_A66] #1886318
08/06/15 03:50 PM
08/06/15 03:50 PM
Indiana
Y
Y
Indiana
I have contacted a "well known" shop to see what they can do with my existing 2.02" J's. They can port them to 275cfm which puts them in the range of the stock W2's and the Indy/IMM heads (which I have looked into previously).
For an appx 425hp build: (new custom cam and rocker gear would be required for each)?:
A) Port existing J's to 275cfm (+ port existing RPM intake)
B) Purchase non-ported Econo W2's 250-260cfm (+ port match W2 intake)
C) Purchase new Indy/IMM heads @ 271cfm (+ port existing RPM intake)
Thanks everyone!
Re: W2 Parts Questions [Re: YO7_A66] #1886358
08/06/15 05:23 PM
08/06/15 05:23 PM
P
Porter67 Offline
Porter67  Offline
P
I have a simple combo/cam for a dyno proven 425 plus build that uses 2.02 J heads with a simple afternoon of cleanup work and a small lift solid.
No need for any kind of heavy porting, and I will look at the head pics as I dont think they needed modified much.
I cant take credit for it, I copied it from mag build and have used the same cam for many builds, its got a very flat tq curve and hits hard from about 1700-6300.
Let me find the pics here as I beat this build to death for three years, street and track.
Re: W2 Parts Questions [Re: YO7_A66] #1886363
08/06/15 05:35 PM
08/06/15 05:35 PM
P
Porter67 Offline
Porter67  Offline
P
Heads had very very little cleanup work to them.
Re: W2 Parts Questions [Re: Porter67] #1886393
08/06/15 06:31 PM
08/06/15 06:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I used Hughes BB Victors on this 440" W2 with the MRL .185" offset rollers, it's pretty "sporty"
WIZE
In Car:
Re: W2 Parts Questions [Re: Porter67] #1886411
08/06/15 07:04 PM
08/06/15 07:04 PM
Indiana
Y
Y
Indiana
I just had another discussion about my three options listed above. It appears that the Indy/IMM heads and the ported J-Heads will be about the same on power but the Indy/IMM will have a slight torque advantage for about the same price. The W2 setup on my combo would suffer do to low torque.
This thread is a huge learning curve for me!
Thanks again to all and Porter, thanks for sharing!!
Re: W2 Parts Questions [Re: Porter67] #1886587
08/06/15 10:23 PM
08/06/15 10:23 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Originally Posted By Porter67
Dip360, them are some good numbers and the temps you used are proven to work. The 11/32 stem helps as well. You could get a hair more but the effort involved imo wouldnt produce the expected returns for the time involved...
Thank you...and yeah, I was pretty happy with the results, I think these heads work with my combo very well.
Here is a pic of what the ports ended up looking like:
Now, if there is anything I'd like to add to this is that it's very much about the combo. I have a 4K stall 9.5" converter in my ride, with 727 auto, 3.91 gear and 275/60-15 tires that car flat out "hauls butt"...now what about the combo you might ask? Well, I experimented with Perfomer RPM intake vs Holley Strip Dominator, there was a noticeable difference between the two...Performer RPM won hands-down for street manners and real butt-meter torque. I have yet to take the car to the track to see what ET difference that might translate to though.
Re: W2 Parts Questions [Re: YO7_A66] #1886885
08/07/15 01:10 PM
08/07/15 01:10 PM
P
Porter67 Offline
Porter67  Offline
P
Dip, you got alot of time in them puppies. I hate iron heads but I do alot of straight six tractor heads.
Here is a old X set thats still in the rough before final cleanup so they look pretty but I also tubed the pushrod tubes and will have to run 5/16 pushrods but that dont bother me as the whole "you got to run 3/8" are more of a mopar cult deal then reality. I had to open the chambers up alot to take a domed piston at a 4.100 bore.
I dont think I can get much more out of these.
But since this is about W2 heads the bottom pic is of a W2 econo chamber and it shows it was thought out a bit better then the older oem x,j heads.
