1985 Chrysler 5th Ave. HVAC Vacuum diagram? #1885695
08/05/15 04:22 PM
08/05/15 04:22 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Hey Guys, does anyone have a diagram for the Vacuum lines on the Heat/Air controls on a 85 5th ave. I am working on one for a 90 yo. Lady, the car only has 29,000 miles like new..But the connector that couples the vacuum lines together from the dash controls to the heater box totally crumbled apart.. I got a good connector from a Dakota, I intend to splice in, but the colors are different, not sure what goes where.. Thanks
Re: 1985 Chrysler 5th Ave. HVAC Vacuum diagram? [Re: EV2RUNNER] #1885720
08/05/15 04:54 PM
08/05/15 04:54 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've done that job. Chrysler had that vacuum harness available for ages. It was fairly inexpensive. The repair is much easier when you can plug and play.
Sorry, I do not have the routing diagram. It was a common repair. There might be something buried in Google.
- Stu Harmon
Re: 1985 Chrysler 5th Ave. HVAC Vacuum diagram? [Re: EV2RUNNER] #1887491
08/08/15 02:26 PM
08/08/15 02:26 PM
Upstate, NY
Prospect62 Offline
Prospect62  Offline
Upstate, NY
Check out what the experts have to say:
http://www.dippy.org/forum2/index.php?topic=179.msg1580#msg1580
And if you don't find it in that post, do some searching around. You'll find your answer there.
1987 Plymouth Gran Fury AHB
