TKO - 500 Shifting Problems #1884687
08/03/15 11:18 PM
08/03/15 11:18 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I have TKO-500 that has been in my car for the last couple of years. On Saturday out of the blue I started having problems shifting into 1st gear. All of the other gears perform as needed but it will not shift into 1st. I am running the hydraulic clutch setup as well. Any help or thoughts would be appreciated.
[image]https://board.moparts.org/ubbthreads/upload2/5353101-YoungGunChallengerNats.jpg[image] My 70 Dodge Challenger R/T SE 383 Magnum, 727, A/C, Cruise, Six-way seat.
Re: TKO - 500 Shifting Problems [Re: faud88] #1884932
08/04/15 01:26 PM
08/04/15 01:26 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Try to bleed the clutch to ensure you didn't pull in air from anywhere. The other gears aren't a problem when shifting, since you don't need a clutch to shift once the RPMs drop and engine speed matches the next hear--it'll fall into gear without using a clutch
**Photobucket sucks**
Re: TKO - 500 Shifting Problems [Re: 70Cuda383] #1885063
08/04/15 05:12 PM
08/04/15 05:12 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
iagree Sounds like your not totally disengaging the clutch.
Re: TKO - 500 Shifting Problems [Re: faud88] #1885120
08/04/15 07:08 PM
08/04/15 07:08 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
How's reverse?
Re: TKO - 500 Shifting Problems [Re: minivan] #1885143
08/04/15 07:41 PM
08/04/15 07:41 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I will try bleeding the clutch again. It shifts into reverse flawlessly.
Re: TKO - 500 Shifting Problems [Re: faud88] #1886056
08/06/15 01:09 AM
08/06/15 01:09 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If it shifts into gear while the engine is off, proceed with disengagement solutions.
Re: TKO - 500 Shifting Problems [Re: faud88] #1886155
08/06/15 10:11 AM
08/06/15 10:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Hmm...that is a strike against it being the hydraulics of the clutch, if it wasn't fully disengaging because of air in the system, it would also be hard to shift into reverse I would think.
Re: TKO - 500 Shifting Problems [Re: faud88] #1886262
08/06/15 02:22 PM
08/06/15 02:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If everything else works flawlessly it may be just a split synchro ring on the first gear hub. If it feels normal going into first with engine off and the shifter looks and feels right then it's probably first synchro issues twocents
Gus beer
64 Plymouth Savoy
Dana 60
