Welded subframeconnectors and e-brake cable #1884895
08/04/15 12:23 PM
08/04/15 12:23 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Does anyone have welded subframeconnectors? I've the Us Car Tool full subframeconnectors in place.
What did you do with the route of the e-brake cable?
Could you share some pictures of it?
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1884903
08/04/15 12:45 PM
08/04/15 12:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I just went through this yesterday, I ran a piece of masking tape from the e-brake cable hole in front to the spot in the rear that the cable runs through. That gave me where the slots had to be cut. I marked where those spots were on the frame connector then took a grinder and ground slots in the frame connectors so the cable can pass through.
It didn't take longer than 10 minutes but now I have to repaint them because of paint burnthrough.
Sheldon
Sheldon
Re: Welded subframeconnectors and e-brake cable [Re: RUNCHARGER] #1886032
08/06/15 12:32 AM
08/06/15 12:32 AM
IN
ahy Offline
ahy  Offline
IN
I have welded 2" x 2" connectors with slot cut in the sides for E brake cables.
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1887962
08/09/15 12:13 PM
08/09/15 12:13 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Sure. These are ART sub frame connectors.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1888756
08/10/15 01:43 PM
08/10/15 01:43 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Thx! This does the trick!
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1888880
08/10/15 04:16 PM
08/10/15 04:16 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
When installed, the e-brake cable rides on above the top of our connector. I can't imagine that elongated holes in the center of the connector do much to add to their rigidity. That adds a huge twist compromise to the integrity of the connector and diminishes it's effectiveness.
Re: Welded subframeconnectors and e-brake cable [Re: Dan@Hotchkis] #1889168
08/10/15 11:38 PM
08/10/15 11:38 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
By "huge" do you mean miniscule? That short section of the beam is now effectively a C-channel, this is not a huge compromise.
Now I agree that closing those holes and guiding the cable over would be a better solution and a little stronger, but I think you are overstating the issue. Frame sections on large trucks often have holes and openings through their sides, the majority of the loads are carried on the top and bottom surfaces of the box / beam structure.
If you were able to quantify the load this beam would actually see we could actually run the numbers, but I doubt the difference would be significant. Now, if you wanted to make this significantly stronger, make it taller, you could still put holes in the sides, it's OK.
And yes, I am a Mechanical Engineer, so, for the sake of argument lets just assume I am correct.
Re: Welded subframeconnectors and e-brake cable [Re: 68cuda440] #1889211
08/11/15 12:25 AM
08/11/15 12:25 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Originally Posted By 68cuda440
[quote=Dan@Hotchkis]
Spoken by a true old school engineer. LOL
Damon
Re: Welded subframeconnectors and e-brake cable [Re: mopardamo] #1889224
08/11/15 12:55 AM
08/11/15 12:55 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Damon
Just trying to have a sense of humor - Moparts lacks that sometimes.
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1889378
08/11/15 11:17 AM
08/11/15 11:17 AM
Well I would be the first to admit I am not an engineer, I'm just a lowly fabricator. However, when coming up with our designs our engineer (Aaron) does all of his wiz-bang stress and failure analysis. That said, I'm fairly confident that a boxed frame is always stronger than an open channel and while you are right that the forces generated may be insignificant enough to render the hole moot. In my opinion, I wouldn't want a gaping hole in my subframe connector where the part would be experiencing the most twist.
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1890133
08/12/15 10:43 AM
08/12/15 10:43 AM
NY NY
3
340duster340 Offline
NY NY
If anything the sub frame connectors are on tension/compression
You would need a hoop in the passenger compartment to be effective at truly minimizing torsion.
I.e. I don't think there is much twist acting on that part.
Ps all the frame rails have drain holes in them! Hurry break out the welder or she's going to blow smile
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Welded subframeconnectors and e-brake cable [Re: dickdale] #1890167
08/12/15 11:33 AM
08/12/15 11:33 AM
The chassis sees significant torsional twist especially when combined with higher spring and sway rates. The rockers (which don't have any holes) are what carry that load and prevent a large amount of the structural rigidity. A great example to this is when jacking up a vehicle by a corner before and after installing the connectors. Our subframe connectors tie the subframes in at a second place, adding to the chassis's ability to resist twist. And yes, adding a proper 6 or 8 point cage reduces an even greater amount of chassis cross flex, since you are controlling it on a broader 3 dimensional space.
Re: Welded subframeconnectors and e-brake cable [Re: Dan@Hotchkis] #1898125
08/24/15 01:44 AM
08/24/15 01:44 AM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
I like to weld in a section of tube angled through the frame connector for the cable to ride through clean simple and strong......... [img]http:// 100-0528[/img]
ACCELERATION SPECIALIST
Re: Welded subframeconnectors and e-brake cable [Re: 340duster340] #1898270
08/24/15 12:44 PM
08/24/15 12:44 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It has never been substantiated here on Moparts exactly what forces the SFC actually resist. With handing my priority, I believe "twist" is my primary concern, and my last set I installed were 2.5" square, with twist resistance my first concern. Drag use would I suspect be more compression/bending forces. The hole for e brake cable is doing the least harm by being located in the vertical center, but being close to mid span is a down side for bending loads, it is larger? then absolutely necessary If I can make out the pic correctly, the oval holes are across from ea other, offset would I think be better, and any compression/tension loads are concentrated at around this hole, not ideal. Good way to make a 2x2 member act like a 1x1 member IMO.
Re: Welded subframeconnectors and e-brake cable [Re: 68cuda440] #1901383
08/28/15 09:19 PM
08/28/15 09:19 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Damon
Re: Welded subframeconnectors and e-brake cable [Re: Dan@Hotchkis] #1904558
09/01/15 11:27 PM
09/01/15 11:27 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I will b upgrading my Mopar with subframe connectors later this year. I'll be getting the new Magnum Force e-body unit for my Cuda.
