can timing affect engine temperature?
#1884685
08/03/15 11:12 PM
08/03/15 11:12 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
I set my 73 stock 400 4 barrel at 15 initial, and 35 total. It never ran so smoothly, and real nice acceleration. While on a nice short cruise on the highway, I ran the A/C. Temp went to the high range. I did the heater trick, and man, was it hot air!!. Coolant is new and full. Clutch and viscus fan are all in good-working condition. Stock 28 inch radiator. It's a Cali car, so I can't imagine this is all kosher. What are your thought? Thanks. Need it worked out for the Nats. By the way, outside temp was only 75. Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: can timing affect engine temperature?
[Re: sunroofgtx]
#1884698
08/03/15 11:36 PM
08/03/15 11:36 PM
RapidRobert
timing is fine. need a better radiator.
[Re: RapidRobert]
#1884704
08/03/15 11:42 PM
08/03/15 11:42 PM
sunroofgtx
Cleveland
timing is fine. need a better radiator. Totally agree..I need a 4 core 28" asap. Something that looks stock. Maybe at the Nats??
[Re: sunroofgtx]
#1884716
08/03/15 11:55 PM
08/03/15 11:55 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
[Re: sunroofgtx]
#1884720
08/03/15 11:59 PM
08/03/15 11:59 PM
sunroofgtx
Cleveland
Cab, roger on that!! Stumpy, yes on the factory shroud. I think the radiator might have gotten changed out in the last 43 years. It only has a 28 2 row. There is a lot of room for more rows, so the fan is inside the shroud a little deeper.
[Re: sunroofgtx]
#1884734
08/04/15 12:11 AM
08/04/15 12:11 AM
Challenger 1
Cincinnati, Ohio
I set my 73 stock 400 4 barrel at 15 initial, and 35 total. It never ran so smoothly, and real nice acceleration. While on a nice short cruise on the highway, I ran the A/C. Temp went to the high range. I did the heater trick, and man, was it hot air!!. Coolant is new and full. Clutch and viscus fan are all in good-working condition. Stock 28 inch radiator. It's a Cali car, so I can't imagine this is all kosher. What are your thought? Thanks. Need it worked out for the Nats. By the way, outside temp was only 75. Thanks Stock 73 400 on today's gas, with stock jetting and carburetor? If so your lean as heck and that where the heat is coming from. I bet you whether I'm right or wrong that riching up the main jet helps a bunch with power and drivability.
[Re: Challenger 1]
#1884766
08/04/15 01:09 AM
08/04/15 01:09 AM
sunroofgtx
Cleveland
I bet you whether I'm right or wrong that richening up the main jet helps a bunch wer and drivability.
I bet you might be correct. It's got an Edelbrock 750 on it. I wish I could get some A/F..lol.. Wonder if I should chassis dyno it..lol I'll need to check the plugs while driving to the Nats. I'll pull off on a rest stop.
[Re: sunroofgtx]
#1884770
08/04/15 01:25 AM
08/04/15 01:25 AM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
shoot a temp laser gun on the radiator to find hot spots/ blocked tubes
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: sunroofgtx]
#1884775
08/04/15 01:35 AM
08/04/15 01:35 AM
RapidRobert
It's got an Edelbrock 750 on it. I wish I could get some A/F..lol.. Wonder if I should chassis dyno it..lol (far) easier yet, block the metering rods up & take it back out for a repeat. You'll have your answer in an hour
[Re: sunroofgtx]
#1884830
08/04/15 06:12 AM
08/04/15 06:12 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Retard the timing 2 degrees and see what happens. It will take you 5 minutes.
Chris from New Jersey
[Re: TJP]
#1884962
08/04/15 02:06 PM
08/04/15 02:06 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What jets are in that stock 750? I may have a few eddy jets/rods if you want to try them. If you put a bung in your exhaust somewhere, I can bring my LM-2 wideband and we can get some readings at cruise to see where you're at
**Photobucket sucks**
[Re: 70Cuda383]
#1884963
08/04/15 02:07 PM
08/04/15 02:07 PM
70Cuda383
Marysville, O-H-I-O
If you don't have a bung, stop by on Thursday. We can weld one in here at the house. Only takes about 15 minutes. I have a few in the shop
[Re: ThermoQuad]
#1885153
08/04/15 08:07 PM
08/04/15 08:07 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
Check your timing chain stretch, you may need to give it more advance as it is running "late" in cam timing. As long as it does not ping don't worry about the total. You may be in need of a new chain and gear set..
Are you suggesting that cam being retarded 2° will cause it to over heat? Or that the igniting timing will be off 2°. Of course the ignition time has nothing to do with cam timing. If the timing light says 15°, it is 15° no matter what the timing chain is doing. And the cam being retarded 2° will not measurably effect heating/cooling.
