Re: Cracked Mains W/ Aluminum Caps
[Re: 6bblFLASH]
#1877765
07/25/15 10:18 AM
07/25/15 10:18 AM
Posts: 4,334 Prospect, PA
BSB67
Prospect, PA
Is this what you are referring too?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136.
If so, seems like it might be a bit more than 600 hp?
[Re: BSB67]
#1877787
07/25/15 11:08 AM
07/25/15 11:08 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
If so, seems like it might be a bit more than 600 hp? The car must weigh 3,000 race ready.
If you can't handle the truth, you're living a lie.......
[Re: sr4440]
#1877794
07/25/15 11:19 AM
07/25/15 11:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would be interested in knowing what the max timing was on the blocks that cracked. the reason i ask is i run 843HP (corrected) on my 400 (aluminum caps and griddle) and we put a blower on one and made 1240 hp but kept cracking upper cylinder walls (that block was cross bolted and had a griddle on it also) I run 31 degrees of timing.
Joe They are cracking for one reason... detonation... to SR4440 31* is a lot on a blower... but other factors also come into play... fuel, wall thickness.. and cam.. and more... to the OP... did you put the alum caps on at day 1 of that build and what was the timing, fuel and cranking pressure
[Re: BSB67]
#1877819
07/25/15 12:02 PM
07/25/15 12:02 PM
Posts: 3,862 N.E. Ohio
6bblFLASH
N.E. Ohio
If so, seems like it might be a bit more than 600 hp? Yes
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1877821
07/25/15 12:09 PM
07/25/15 12:09 PM
6bblFLASH
N.E. Ohio
Detonation and general abuse are the most likely culprits. I have proof that #4 cyl has seen detonation over the years. Flow in the intake is pretty bad on#4.
I`m wanting a bigger cube and less compression like 10.5 or so.
Any opinion on 383 blocks?
[Re: 6bblFLASH]
#1877842
07/25/15 12:52 PM
07/25/15 12:52 PM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
Many years ago when I was just learning, someone told me that if I want to make it live I needed to go with a 400 block with aluminum caps and no girdle. So I tried it, and made 9 second passes for about 7 years, then ran that same type of combo in another 9 second car for 5 years. Everyone has their own opinions, I'm just telling you what worked for me. I don't know why, but all my friends that have blown up their motors over the years, have all been RB blocks. But alot of guys here on Moparts run them every weekend.
[Re: MR_P_BODY]
#1877868
07/25/15 01:32 PM
07/25/15 01:32 PM
Posts: 730 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Joe They are cracking for one reason... detonation... to SR4440 31* is a lot on a blower... but other factors also come into play... fuel, wall thickness.. and cam.. and more... to the OP... did you put the alum caps on at day 1 of that build and what was the timing, fuel and cranking pressure I am sorry, 31 was on my NA junk. I think we were around 21-22 with 10 PSI of boost on the blower. Joe
Without Data, you’re just another guy with an opinion.
[Re: AndyF]
#1877887
07/25/15 02:26 PM
07/25/15 02:26 PM
Posts: 176 Sterling Heights, MI
John_T_Brown
If you have more 440 blocks and all of your parts are for RB engines then I'd build another 440. You might just think hard about ways to reduce detonation and reduce problems for the bottom end. Aluminum rods might help, double check the balance job on the rotating assembly, careful look at the tops of the pistons and the combustion chambers, double check your AF numbers, etc. You might have a distribution problem and maybe one cylinder is running lean and you don't know it. 6bbl systems are fairly famous for having problems like that. +1 The major problem with stock block main problems are with balance, anything that disrupts that (bob weight, fuel mixture, timing, etc.) will cause the bottom end to do ugly things. Here is an excellent article on the subject Engine Balance
If it ain't broke fix it anyway!
[Re: sr4440]
#1877950
07/25/15 04:54 PM
07/25/15 04:54 PM
Posts: 2,141 junction city oregon
viperblue72
Joe They are cracking for one reason... detonation... to SR4440 31* is a lot on a blower... but other factors also come into play... fuel, wall thickness.. and cam.. and more... to the OP... did you put the alum caps on at day 1 of that build and what was the timing, fuel and cranking pressure I am sorry, 31 was on my NA junk. I think we were around 21-22 with 10 PSI of boost on the blower. Joe A 400 block is a different ball game. Much more rigid block.
[Re: sr4440]
#1877970
07/25/15 05:29 PM
07/25/15 05:29 PM
MR_P_BODY
Joe They are cracking for one reason... detonation... to SR4440 31* is a lot on a blower... but other factors also come into play... fuel, wall thickness.. and cam.. and more... to the OP... did you put the alum caps on at day 1 of that build and what was the timing, fuel and cranking pressure I am sorry, 31 was on my NA junk. I think we were around 21-22 with 10 PSI of boost on the blower. Joe Years ago I ran a 383 block but with a destroked engine that turned some high rpm...everything was light and it was a tunnel ram.. I measured EGT on all cyls just to see if the flow balance was decent... that engine lasted till I sold the car and it was still running.. of course this was before the 400 blocks
[Re: 6bblFLASH]
#1880087
07/28/15 02:16 PM
07/28/15 02:16 PM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
I can clearly see I got away with a potential disaster. Block was not "fresh" and really have no record of its history. So now the debate in my head,,,,,lots of empty space for a debate in there.... Low deck or another RB. I was looking at some of those 383 strokers. I DO have 3 virgin 383 blocks and 3 virgin 440`s Don`t want more power,just a little more confidence in my engine.... Opinions I would say build a low deck , but get a 400 ... this is coming from the guy that is building 383's, but if you go with a 440 use a late block .
[Re: Cab_Burge]
#1880153
07/28/15 03:57 PM
07/28/15 03:57 PM
6bblFLASH
N.E. Ohio
Lots of ideas to ponder,,,,, thanks for the advise.
Simple math is an aftermarket block is out of the question. Last 5 years I`ve probably only made 100 passes. Only go zero to 5 times a year anymore.
In all likelyhood it will be summer 2016 before it makes another pass.
I have the stuff already to build the same+.030 block,crank etc...
Want something better......... Like the idea of a 400 stroker more cubes less compression.
I`ll get some pictures of the parting line
[Re: 6bblFLASH]
#1880167
07/28/15 04:13 PM
07/28/15 04:13 PM
Posts: 4,457 Washington
madscientist
Washington
Some how we have gotten to the point where guys making 600 real HP (as the OP says he is) don't think they need an aftermarket block. Not only is reliabilty down using P car blocks so is your HP. Your tune up window is significantly reduced, so a minor tuning error will cost you big time.
If you can't afford/want an aftermarket block, think about a reduction in HP and RPM. What you are using was never designed to have done to it what you are doing. All the tricks in the world won't help that.
