Textured dash paint - Rustoleum "durability" ???
#1883708
08/02/15 07:21 PM
08/02/15 07:21 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've started to redo the steering column and dash. It would seem there are three common options to duplicate the texture: a) powdercoat - since my dash has some rust pitting and will need some bondo, this is not an option. This would without a doubt be the most durable BUT if it isn't perfect on the first pass, redoing it can be a real hassle. b) reproduction paint - the cost for a small amount is quite high. Since its a lacquer, durability is questionable. There seem to be issues with duplicating the finish although that's probably more due to the equipment and the user. c) Rustoleum rattle can - by far the least expensive and easiest method. The downside is that while the finish is virtually bang on, it has just a little too much gloss - the original being "flatter".
For my application the rattle can finish will do just fine HOWEVER, I'm concerned about durability. For those who have used the Rustoleum "textured" finish, what's your experience?
Re: Textured dash paint - Rustoleum "durability" ???
[Re: Stanton]
#1883982
08/03/15 12:24 AM
08/03/15 12:24 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I found some black paint for BBQ grills years ago at my True Value that was semi flat and had a light texture like the dash paint. I think it was specifically for Weber grills. It was designed to be durable and stand the heat. If you can find some, it may be worth checking out to see how it looks?
[Re: Stanton]
#1884086
08/03/15 04:35 AM
08/03/15 04:35 AM
Posts: 114 Oregon
Wagonman1967
Yep I just redid the dash and column in the 68 with the Rustoleum textured. Looks pretty good but time will tell on the durability. dosent seem to scratch easily and yes it baked in the sun for a day.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: Wagonman1967]
#1884114
08/03/15 09:15 AM
08/03/15 09:15 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
I found the rustoleum attains the texture by using metallic. The finish is spot on, you just need to overcoat it with a flat finish.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: Stanton]
#1884166
08/03/15 11:10 AM
08/03/15 11:10 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
rustoleum attains the texture by using metallic. metallic ?!? What are you using it on? Right out of the can the "textured" nails the finish, the only issue being the degree of gloss. I'm afraid a shot of semigloss clear would tend to level out the texture.
[Re: Stanton]
#1884518
08/03/15 07:12 PM
08/03/15 07:12 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have for years used Totally Autos Organisol Black. It already has the texture in it and it holds up. Thanks but this has nothing to do with the post. We're specifically discussing Rustoleum textured paint. We're all well aware that there are other options out there.
[Re: Stanton]
#1884554
08/03/15 08:10 PM
08/03/15 08:10 PM
Posts: 601 Mass
charge70
Mass
I used the Rustoleum textured paint on my dash and steering column.It looks real close to oem but I think the texture is a little to coarse.You have to be very careful with what you use when you wipe them off.If I had to do it over I think I would use the correct interior paint.As far as durability I can't answer that as the car has only been done for a month now,time will tell. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: Stanton]
#1884729
08/04/15 12:09 AM
08/04/15 12:09 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
i would say it would have alot better durability as compared to a laquer paint. That is one reason I decided to try the Rustoleum. I think the factory did put the dashes through a bake cycle though - the stuff is pretty tough!
[Re: Stanton]
#1884755
08/04/15 12:45 AM
08/04/15 12:45 AM
Big D A12
Wisconsin
rustoleum attains the texture by using metallic. metallic ?!? What are you using it on? Right out of the can the "textured" nails the finish, the only issue being the degree of gloss. I'm afraid a shot of semigloss clear would tend to level out the texture. Take the "textured" black Rustoleum paint in bright sunlight. Like it would be under your windsheild atop your dash. You will see what I mean, it reflects back at you. If it works for you great, I was not happy with it. I am just sharing my experience with the can of paint we had. D
[Re: Big D A12]
#1884893
08/04/15 12:15 PM
08/04/15 12:15 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Oh, now I understand what you mean. I don't see any evidence of metallic particles, just the gloss of the paint.
I would be interesting to hear from some paint expert just what they use to achieve the finish. Back in the day it was called "suede additive".
In the early '80's I had a local paint supplier make me a spray bomb. I would have used it except that over time either the propellant has seeped out or the nozzle tube has plugged. The paint in the car is still liquid but it just won't spray. How's that for procrastinating ... over 30 years I've been meaning to do this !!!
