Textured dash paint - Rustoleum "durability" ??? #1883708
08/02/15 07:21 PM
08/02/15 07:21 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I've started to redo the steering column and dash. It would seem there are three common options to duplicate the texture:
a) powdercoat - since my dash has some rust pitting and will need some bondo, this is not an option. This would without a doubt be the most durable BUT if it isn't perfect on the first pass, redoing it can be a real hassle.
b) reproduction paint - the cost for a small amount is quite high. Since its a lacquer, durability is questionable. There seem to be issues with duplicating the finish although that's probably more due to the equipment and the user.
c) Rustoleum rattle can - by far the least expensive and easiest method. The downside is that while the finish is virtually bang on, it has just a little too much gloss - the original being "flatter".
For my application the rattle can finish will do just fine HOWEVER, I'm concerned about durability. For those who have used the Rustoleum "textured" finish, what's your experience?
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1883841
08/02/15 10:22 PM
08/02/15 10:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have restoleum texture on my minilite rims. 3 of them I painted and then baked in the oven. One I just let air dry.
That one knicks easier than the other 3 three. It's got a couple knicks from removing lug nut if I use a deep socket. All have held up pretty decent. Been 5 years since I've been running them.
Have you tried putting a light fog over the final coat to dull it a little?
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1883902
08/02/15 11:20 PM
08/02/15 11:20 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I thought of doing the light fog but that will roughen the texture to the point of being too much. Baking isn't an option because some things - like the dash - are just too big. I've been leaving them in the hot sun - black really soaks up the rays !!
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1883982
08/03/15 12:24 AM
08/03/15 12:24 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I found some black paint for BBQ grills years ago at my True Value that was semi flat and had a light texture like the dash paint. I think it was specifically for Weber grills. It was designed to be durable and stand the heat. If you can find some, it may be worth checking out to see how it looks?
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884086
08/03/15 04:35 AM
08/03/15 04:35 AM
W
Wagonman1967 Offline
W
Yep I just redid the dash and column in the 68 with the Rustoleum textured. Looks pretty good but time will tell on the durability. dosent seem to scratch easily and yes it baked in the sun for a day.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Wagonman1967] #1884114
08/03/15 09:15 AM
08/03/15 09:15 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
I found the rustoleum attains the texture by using metallic. The finish is spot on, you just need to overcoat it with a flat finish.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884166
08/03/15 11:10 AM
08/03/15 11:10 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
metallic ?!? What are you using it on? Right out of the can the "textured" nails the finish, the only issue being the degree of gloss. I'm afraid a shot of semigloss clear would tend to level out the texture.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884174
08/03/15 11:24 AM
08/03/15 11:24 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Do you guys shoot a primer before the texture? There's no primer under the factory finish and rustoleum is usually a "direct application" product. Just curious. The dash is next and that's the only thing that can't be taken out and redone (easily) if something happens!
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884350
08/03/15 03:27 PM
08/03/15 03:27 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
I have for years used Totally Autos Organisol Black.
It already has the texture in it and it holds up.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884518
08/03/15 07:12 PM
08/03/15 07:12 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Thanks but this has nothing to do with the post. We're specifically discussing Rustoleum textured paint. We're all well aware that there are other options out there.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884554
08/03/15 08:10 PM
08/03/15 08:10 PM
Mass
charge70 Online content
charge70  Online Content
Mass
I used the Rustoleum textured paint on my dash and steering column.It looks real close to oem but I think the texture is a little to coarse.You have to be very careful with what you use when you wipe them off.If I had to do it over I think I would use the correct interior paint.As far as durability I can't answer that as the car has only been done for a month now,time will tell. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884653
08/03/15 10:25 PM
08/03/15 10:25 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
rustolem enamel paint is some pretty tough stuff.
thier products have a few issues with compatability
with other products and it will gator if
you put it near something it doesn't like.
i would say it would have alot better durability
as compared to a laquer paint.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884729
08/04/15 12:09 AM
08/04/15 12:09 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
That is one reason I decided to try the Rustoleum.
I think the factory did put the dashes through a bake cycle though - the stuff is pretty tough!
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884755
08/04/15 12:45 AM
08/04/15 12:45 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Take the "textured" black Rustoleum paint in bright sunlight. Like it would be under your windsheild atop your dash. You will see what I mean, it reflects back at you. If it works for you great, I was not happy with it. I am just sharing my experience with the can of paint we had.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Big D A12] #1884893
08/04/15 12:15 PM
08/04/15 12:15 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Oh, now I understand what you mean. I don't see any evidence of metallic particles, just the gloss of the paint.
I would be interesting to hear from some paint expert just what they use to achieve the finish. Back in the day it was called "suede additive".
In the early '80's I had a local paint supplier make me a spray bomb. I would have used it except that over time either the propellant has seeped out or the nozzle tube has plugged. The paint in the car is still liquid but it just won't spray. How's that for procrastinating ... over 30 years I've been meaning to do this !!!
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884936
08/04/15 01:28 PM
08/04/15 01:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I painted my 68 Dart dash frame with it. I also sprayed it with a semi-gloss clear. I don't think it looks too glossy. I am worried about how well it is going to hold up.
Re: Textured dash paint - Rustoleum "durability" ??? [Re: burdar] #1884948
08/04/15 01:47 PM
08/04/15 01:47 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What brand of clear did you use? Does the texture still come through? I'll try it but don't want the paint peeling because the clear is incompatible!
Re: Textured dash paint - Rustoleum "durability" ??? [Re: Stanton] #1884953
08/04/15 01:57 PM
08/04/15 01:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used Rustoleum clear. The texture still shows through.
