440 engine coolant capacity #1881079
07/29/15 09:33 PM
07/29/15 09:33 PM
North Carolina USA
P
Provolare Offline OP
P
North Carolina USA
I am trying to get an idea of much water a stock 440 holds..Just the engine itself and nothing else? Any help appreciated..
Re: 440 engine coolant capacity [Re: Provolare] #1881333
07/30/15 04:13 AM
07/30/15 04:13 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
My guess is most of it.... Or more than half in the engine.
What vehicle is your 440 in? Never needed to measure it on mine. Suppose you could remove the thermostat, close off the bottom hose, fill then drain and measure the quantity if no one else has a quick and easy answer.
Considering the system, there is space for water (or coolant) in the upper and lower hoses, heater core, heater hoses, top and bottom tanks and tubes in the radiator; All the rest is in the heads, block, water pump, etc.
Here is a link to vintage cooling system capacities:
http://vintage.mitchell1.com/PClubData/chassis/den73/V2D735217.pdf
Total coolant system capacity, (guessing roughly around 18 quarts or 4 1/2 gallons) less items above.
Perhaps a Radiator Shop person can check in. At least you have a reply and BTT.
Re: 440 engine coolant capacity [Re: Provolare] #1881683
07/30/15 06:57 PM
07/30/15 06:57 PM
North Carolina USA
P
P
North Carolina USA
Thanks for the reply..I was talking engine only..no hoses ..no nothing just block, heads, internal capacity.
I am guessing 3-31/2 gals.?
Thanks..
Re: 440 engine coolant capacity [Re: Provolare] #1881806
07/30/15 10:34 PM
07/30/15 10:34 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
You are probably close in that guess. I was cleaning the water jackets out on my 440 block with the WD40 rust soak stuff, and each side on the block held just under a gallon.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: 440 engine coolant capacity [Re: runnerrt] #1882414
07/31/15 06:55 PM
07/31/15 06:55 PM
North Carolina USA
P
P
North Carolina USA
Thanks..Pry is close to 3 total in the engine?
Re: 440 engine coolant capacity [Re: Provolare] #1882654
08/01/15 01:49 AM
08/01/15 01:49 AM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
3 total would be close. If there is 2 in the block and a gallon in the heads sounds realistic.
Re: 440 engine coolant capacity [Re: runnerrt] #1883634
08/02/15 05:17 PM
08/02/15 05:17 PM
North Carolina USA
P
P
North Carolina USA
Thank you..
