Page 2 of 6 1 2 3 4 5 6
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877765
07/25/15 11:18 AM
07/25/15 11:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Is this what you are referring too?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136.
If so, seems like it might be a bit more than 600 hp?
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877767
07/25/15 11:19 AM
07/25/15 11:19 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Sorry to see that. I think you should just stop messing with these money pits and sell me the roller - lol.
In all seriousness though -
1. Do you run stock firing order?
2. If so, can you post up a few photo's of the mating surfaces, both the block and cap of the #4 main.
Thanks.
Re: Cracked Mains W/ Aluminum Caps [Re: BSB67] #1877787
07/25/15 12:08 PM
07/25/15 12:08 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
The car must weigh 3,000 race ready.
If you can't handle the truth, you're living a lie.......
Re: Cracked Mains W/ Aluminum Caps [Re: sr4440] #1877794
07/25/15 12:19 PM
07/25/15 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By sr4440
I would be interested in knowing what the max timing was on the blocks that cracked. the reason i ask is i run 843HP (corrected) on my 400 (aluminum caps and griddle) and we put a blower on one and made 1240 hp but kept cracking upper cylinder walls (that block was cross bolted and had a griddle on it also) I run 31 degrees of timing.
Joe
They are cracking for one reason... detonation... to SR4440
31* is a lot on a blower... but other factors also come into
play... fuel, wall thickness.. and cam.. and more... to the
OP... did you put the alum caps on at day 1 of that build and
what was the timing, fuel and cranking pressure
wave
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877815
07/25/15 12:57 PM
07/25/15 12:57 PM
AndyF Offline
AndyF  Offline
If you have more 440 blocks and all of your parts are for RB engines then I'd build another 440. You might just think hard about ways to reduce detonation and reduce problems for the bottom end. Aluminum rods might help, double check the balance job on the rotating assembly, careful look at the tops of the pistons and the combustion chambers, double check your AF numbers, etc. You might have a distribution problem and maybe one cylinder is running lean and you don't know it. 6bbl systems are fairly famous for having problems like that.
Re: Cracked Mains W/ Aluminum Caps [Re: BSB67] #1877819
07/25/15 01:02 PM
07/25/15 01:02 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Yes
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877821
07/25/15 01:09 PM
07/25/15 01:09 PM
N.E. Ohio
N.E. Ohio
Detonation and general abuse are the most likely culprits.
I have proof that #4 cyl has seen detonation over the years.
Flow in the intake is pretty bad on#4.
I`m wanting a bigger cube and less compression like 10.5 or so.
Any opinion on 383 blocks?
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877838
07/25/15 01:37 PM
07/25/15 01:37 PM
AndyF Offline
AndyF  Offline
440 blocks are usually stronger than 383 blocks but 400 blocks might be better than either. Hard to say really with any certainty. This stuff is all 40+ years old.
More cubes and less compression might be the ticket. A 4.25 crank in a 440 builds a 505. With 6.80 or 7.10 rods you have a super nice bottom end and plenty of room for a dished piston to get you to 10.5 compression. You can change the gearing and run lower engine speed while still having the same basic power and same ET.
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1877842
07/25/15 01:52 PM
07/25/15 01:52 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Many years ago when I was just learning, someone told me that if I want to make it live I needed to go with a 400 block with aluminum caps and no girdle. So I tried it, and made 9 second passes for about 7 years, then ran that same type of combo in another 9 second car for 5 years. Everyone has their own opinions, I'm just telling you what worked for me. I don't know why, but all my friends that have blown up their motors over the years, have all been RB blocks. But alot of guys here on Moparts run them every weekend.
Re: Cracked Mains W/ Aluminum Caps [Re: MR_P_BODY] #1877868
07/25/15 02:32 PM
07/25/15 02:32 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
Joe
wave
I am sorry, 31 was on my NA junk. I think we were around 21-22 with 10 PSI of boost on the blower.
Joe
Without Data, you’re just another guy with an opinion.
Re: Cracked Mains W/ Aluminum Caps [Re: AndyF] #1877887
07/25/15 03:26 PM
07/25/15 03:26 PM
Sterling Heights, MI
John_T_Brown Offline
+1
The major problem with stock block main problems are with balance, anything that disrupts that (bob weight, fuel mixture, timing, etc.) will cause the bottom end to do ugly things.
Here is an excellent article on the subject Engine Balance
If it ain't broke fix it anyway!
Re: Cracked Mains W/ Aluminum Caps [Re: John_T_Brown] #1877895
07/25/15 03:43 PM
07/25/15 03:43 PM
All three RB blocks(1 426 M.W., two 440) I've seen up until now that cracked the main webs where under #1 and #3 cylinders up towards the cylinder walls shruggy I've seen other GM blocks crack the mains like the one pictured here, me thanks that is mainly weakness in the castings and design work
Re: Cracked Mains W/ Aluminum Caps [Re: sr4440] #1877950
07/25/15 05:54 PM
07/25/15 05:54 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Joe
wave
Joe
A 400 block is a different ball game. Much more rigid block.
Re: Cracked Mains W/ Aluminum Caps [Re: sr4440] #1877970
07/25/15 06:29 PM
07/25/15 06:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Joe
wave
Joe
Years ago I ran a 383 block but with a destroked engine
that turned some high rpm...everything was light and
it was a tunnel ram.. I measured EGT on all cyls just
to see if the flow balance was decent... that engine
lasted till I sold the car and it was still running..
of course this was before the 400 blocks
wave
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1880087
07/28/15 03:16 PM
07/28/15 03:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted By 6bblFLASH
I can clearly see I got away with a potential disaster.
Block was not "fresh" and really have no record of its history.
So now the debate in my head,,,,,lots of empty space for a debate in there....
Low deck or another RB.
I was looking at some of those 383 strokers.
I DO have 3 virgin 383 blocks and 3 virgin 440`s
Don`t want more power,just a little more confidence in my engine....
Opinions fan
I would say build a low deck , but get a 400 ... this is coming from the guy that is building 383's, but if you go with a 440 use a late block .
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1880117
07/28/15 04:02 PM
07/28/15 04:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
My advice would be to buy a good block........which would likely eliminate the chance of you being here in a 150 more passes with the same type pictures, asking for opinions on what to do.
You guys can talk about detonation, balance and all this other stuff. Doesn't change the fact that the blocks are weak there and any 30 year old block to be used as a race block is a serious crap shoot. Even if it is out of your one owner, 67 model grandma car that only has a few thousand miles and never driven over 30mph............Still don't mean a damn thing..........it's a stock block.
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1880122
07/28/15 04:09 PM
07/28/15 04:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Agree the only true solution is an aftermarket block. That is another can of worms for sure. Best bandaid IMO is aluminum caps, aluminum rods, and keep the bobweight as low as possible. Low deck in generally considered stronger than a tall deck deal and will be a lighter bobweight. Detonation will certainly speed up the demise of either one for sure. So your choice. Spend the money on a stock block and cross your fingers or pony up for an aluminum block as that is all that's out there except for those of us hoarding steel ones smile
Re: Cracked Mains W/ Aluminum Caps [Re: Monte_Smith] #1880124
07/28/15 04:11 PM
07/28/15 04:11 PM
work iagree upI talked to Ken Black last week about one of his street wedge blocks, costs, time and options. I'll use the 400 block supply up that I have for most not all out builds and use the Koleno and World blocks I have for the serious builds up
Re: Cracked Mains W/ Aluminum Caps [Re: Cab_Burge] #1880153
07/28/15 04:57 PM
07/28/15 04:57 PM
N.E. Ohio
N.E. Ohio
Lots of ideas to ponder,,,,, thanks for the advise.
Simple math is an aftermarket block is out of the question.
Last 5 years I`ve probably only made 100 passes.
Only go zero to 5 times a year anymore.
In all likelyhood it will be summer 2016 before it makes another pass.
I have the stuff already to build the same+.030 block,crank etc...
Want something better.........
Like the idea of a 400 stroker more cubes less compression.
I`ll get some pictures of the parting line
Re: Cracked Mains W/ Aluminum Caps [Re: 6bblFLASH] #1880167
07/28/15 05:13 PM
07/28/15 05:13 PM
Washington
madscientist Offline
Washington
Some how we have gotten to the point where guys making 600 real HP (as the OP says he is) don't think they need an aftermarket block. Not only is reliabilty down using P car blocks so is your HP. Your tune up window is significantly reduced, so a minor tuning error will cost you big time.
If you can't afford/want an aftermarket block, think about a reduction in HP and RPM. What you are using was never designed to have done to it what you are doing. All the tricks in the world won't help that.
