Re: 1973 dodge dart a/c problem...
[Re: 05dakota]
#1880946
07/29/15 06:15 PM
07/29/15 06:15 PM
Posts: 553 DE
Ply72rr
DE
the gasket I used looks like the second link I think the gasket in the second link is for the low pressure hose at the back of the compressor and the one in the first link is for the high pressure hose at the front of the compressor.
[Re: 05dakota]
#1880968
07/29/15 06:56 PM
07/29/15 06:56 PM
Posts: 17,862 albany ny
05dakota
albany ny
no pay will the first gasket fit there
5549 post on old board
[Re: 05dakota]
#1881325
07/30/15 03:49 AM
07/30/15 03:49 AM
05dakota
albany ny
I ordered a pack of the first 1
[Re: 05dakota]
#1886355
08/06/15 05:08 PM
08/06/15 05:08 PM
05dakota
albany ny
got the gaskets but no sucess. apperars the flange on the output hose isnt flat. tried using a file but it appears the part where the hose is made to the flange is highter than the sides. anyidea where to get the entire hi side out to the condensor?
[Re: 05dakota]
#1887252
08/08/15 12:18 AM
08/08/15 12:18 AM
05dakota
albany ny
I have no idea what to do, this line sees over 100 psi and the gasket leaks at 30 psi
[Re: 05dakota]
#1887427
08/08/15 12:35 PM
08/08/15 12:35 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A file will leave a really rough finish that will not seal.
You either need to replace the bad part or pull it off the car and lap it flat.
[Re: 05dakota]
#1887902
08/09/15 04:40 AM
08/09/15 04:40 AM
05dakota
albany ny
problem is there are no replacements for this part
[Re: 05dakota]
#1887943
08/09/15 11:23 AM
08/09/15 11:23 AM
05dakota
albany ny
FEETS, explain how to lap it flat?
[Re: 05dakota]
#1888460
08/09/15 11:46 PM
08/09/15 11:46 PM
05dakota
albany ny
exactly my problem, how do I make it flat?
