How does a neutral safety switch work? #1880273
07/28/15 07:47 PM
07/28/15 07:47 PM
Badge Offline OP
Badge  Offline OP
I am wondering if the switch sends 12 volts to the solenoid when it is in park? Or, does it remove the voltage? I am assuming the simple switches on 727 transmissions are nothing more than a voltage switch?
Re: How does a neutral safety switch work? [Re: Badge] #1880279
07/28/15 07:54 PM
07/28/15 07:54 PM
Kirkland, Washington
Pacnorthcuda Offline
The switch provides the ground to the starter relay (when engaged) and disconnects the ground if not in park or neutral.
Also operates the back up lights, as a secondary/dual purpose.
Re: How does a neutral safety switch work? [Re: Pacnorthcuda] #1880343
07/28/15 10:11 PM
07/28/15 10:11 PM
Badge Offline OP
Badge  Offline OP
Ah, so it is the ground. The 12V must be for the backups?
Re: How does a neutral safety switch work? [Re: Badge] #1880354
07/28/15 10:26 PM
07/28/15 10:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The center terminal is the ground for the starter relay and the two outside terminals are in and out for back up lights.
Re: How does a neutral safety switch work? [Re: stumpy] #1880441
07/29/15 12:17 AM
07/29/15 12:17 AM
Badge Offline OP
Badge  Offline OP
Thanks guys. I appreciate your knowledgeable help.
