Re: Tunnel Ram and fuel slosh issues ?
[Re: Tig]
#1895440
08/19/15 04:33 PM
08/19/15 04:33 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Another q, Does anyone run jet extensions with these floats? All the floats are notched so do I need 'em?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1919946
09/26/15 09:16 AM
09/26/15 09:16 AM
Tig
A shed in England
Still got issues, also my AFR's change with each gearchange. Usually in the 10's in first 11's in second and 12's in 3rd. Steps coincide with gearchanges.
[Re: Jerry Kathe]
#1920455
09/27/15 09:26 AM
09/27/15 09:26 AM
Tig
A shed in England
Hi Jerry. Yes we got these and tried them. Still all sorts of weird issues with fueling. I'm guessing we need to seal the carbs to the scoop and run a decent air filter before we can get to grips with it. Our season is finished now lots of work to be done on the car before it's next out, modifying they scoop is one of them.
[Re: Jerry Kathe]
#1920477
09/27/15 10:37 AM
09/27/15 10:37 AM
Posts: 151 N.E. Ohio
OhioGTX
N.E. Ohio
Interesting Topic. I have been running a tunnel ram for the past 6 years and experienced a similar set of circumstances a few years back. I had been running with zero problems and then changed cylinder heads to E-Victors. The change moved the carbs very close to the six pack scoop. The Car would launch hard but then a strong bog/failure about 40 feet out. What I found was a simple fix, I removed the hood, exposing the carbs with no restriction above them, the problem resolved immediately. Since then I have been running a flat hood with a halibrand style scoop. No more problems.
I have standard 4150 bowl floats with no jet extensions. Floats are set a little high but nothing radical. No way to say this is the problem you are experiencing, but it is a simple experiment to determine.
As a side note, I came across the idea of removing the hood after talking with very well known local pro-stock carb builder. His rule of thumb was simple, you should be able to place your fist between the carb and the top of the scoop, if not, your experiences may vary.
68 GTX, 9.38 at 144, Best Machine 540..
[Re: Tig]
#1920631
09/27/15 02:34 PM
09/27/15 02:34 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I also had the same problem on my Dart with a hemi scoop took it to the track with a dominator on top of 2" adaptor and victor intake, did 3 runs, first was 121, so i jetted up a couple, the next 2 were 122, on the same day i swapped my old 950 with 2" supersucker back on and it picked up 5 mph the next 2 runs. Ran the car without the hood next time out with the dominator back on and it ran it's best ever speed. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Jerry Kathe]
#1920666
09/27/15 03:20 PM
09/27/15 03:20 PM
Tig
A shed in England
Hello Tig. You shouldn't have floats with notches, you need floats that are shaped like a wedge on one end, these will be orientated left and right with the wedge facing reward. I have never seen tunnel ram floats with jet extension notches and wedge features on the same float. Jet extensions are not necessary (or desired) with sideways mounted carburetors. I would go back and visit that before trying anything else. The floats have wedges and are fitted so the wedge is to the rear, they also have notches for jet extensions. They are not the same as the ones linked to at the start of the thread. http://www.quickfueltechnology.com/fuel-bowl-parts/nitrophyl-float-wedge-primary.htmlPretty sure my hood is causing a problem as we can only just get a 2 1/2 inch tall filter in there. We have filter tops too which are real close to the hood.
[Re: Tig]
#1920742
09/27/15 05:54 PM
09/27/15 05:54 PM
deaks
robin hood country
If it's lift off do a run without the hood and the filters, if it cures the problem then get some less restrictive filters and fit a different scoop. Mick
