1956 CHRYSLER New PorT HEMI STARTER stays engaged..
#1870056
07/14/15 11:27 AM
07/14/15 11:27 AM
Posts: 5 FL
Orlandohemi
FL
Hi every one I have a 1956 Chrysler New Port , inside it has the early hemi Engine 331-349 to my best knowledge ,"I'm a rookie" Got the car from a older gentleman, who said the car used to run fine before it was parked about 2yrs ago. First thing he told me was to get the starter and carburetor redone, so I pulled out the starter and sent it to my local repair shop, with in a few hours done , put the starter back on the car hiT the Key , the starter turns the engine over and WONT STOP un less I disconnect the battery.. Being my first Chrysler I really don't know much i see it has a relay box, which I'm unfamiliar about , I can also jump start it from this box "next to the battery" and the starter kicks on but agin wont disengage until I disconnect the battery... I've had a couple people come and look at it , with no results. I've also looked online for any info and rarely even see any info about this 1956 Chrysler new port alone .. ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) Please any help would be appreciated.. Thank all of you in Advance..
Re: 1956 CHRYSLER New PorT HEMI STARTER stays engaged..
[Re: Orlandohemi]
#1870060
07/14/15 11:53 AM
07/14/15 11:53 AM
Posts: 21,147 Niles , Ohio
therocks
Niles , Ohio
To start with If you have the N start button it might be sticking.My 57 had it as did a few later years.The switch on the block is supposed to disengage the starter when they start.It has 2 prongs and not very big.Rocky
Chrysler Firepower
[Re: Orlandohemi]
#1870081
07/14/15 12:52 PM
07/14/15 12:52 PM
Posts: 44,242 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1870311
07/14/15 07:20 PM
07/14/15 07:20 PM
Posts: 27,383 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
Those starters have a piggyback solinoid Not on a '56, the starter motor is powered directly from the firewall solenoid switch. I'd suspect the firewall solenoid is th culprit. Oh, BTW, welcome to the board Orlandohemi.
[Re: Orlandohemi]
#1879173
07/27/15 02:08 PM
07/27/15 02:08 PM
therocks
Niles , Ohio
Newport was probally a 354 poly.Very easy to tell from hemis as hemi plugs go thru valve cover.Only NewYorkers Imperials and 300s were supposed to get hemis.Rocky
Chrysler Firepower
[Re: Orlandohemi]
#1879548
07/27/15 09:12 PM
07/27/15 09:12 PM
therocks
Niles , Ohio
I agree its a New Yorker with a as said 354 hemi.From the looks its a solid car.Dont know how much you have in it but its woth some money to get it up and going.Sadly 56s arent the biggest sellers as most want either a 55 or 57/58.I like them even though 57s are my favorites.Rocky
Chrysler Firepower
[Re: Orlandohemi]
#1883459
08/02/15 11:28 AM
08/02/15 11:28 AM
Posts: 1,542 AZ
Mike P
AZ
Looking at the video at the 36 second mark https://www.youtube.com/watch?v=lZI0U_49vLw&feature=youtu.be I could be wrong, but I'm not so sure that's a 354. As far as I know, early 1955 was the last year for the 1st Gen Fire Power Hemis used a wet intake that had a thermostat housing in it. From that point on the heads directed the water out of ports in the front of the heads thru a crossover pipe (part of the water pump housing assembly). Additionally the oil fill was relocated to the valley pan and centered almost directly behind the thermostat housing. Passenger car 354s were one year only in 56 (unless you're counting the fifty or so 57 Dodge D501s) and I believe all incorporated those changes.....at least my 354 does. At a glance I would say it's an earlier 331. The only real way to know is look at the engine number located under the thermostat housing just in front of the leading edge of the valley pan.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
