Re: denso alt upgrade
[Re: roadrunnerreds]
#1877898
07/25/15 03:46 PM
07/25/15 03:46 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
While it was running were you able to look at the volt gauge, if you have one? I put a Toyota Denso on my Duster and love it, shows 14 volts on my volt gauge, battery never dies, nothing runs hot. If I remember correctly it was a 2 wire hookup, one went to the battery and one went to an 'ignition start' wire so it only had power when turning the key to the momentary start position.
#1878691
07/26/15 10:09 PM
07/26/15 10:09 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
SO 12.3 is likely not charging at all, that's just what the battery was when the alt got smoked. Whos alternator was it? Check ALL the wiring to make sure nothing is grounded out on any of them. I smoked one alternator over the years and it was from a wire that rubbed through on a frame rail.
#1878734
07/26/15 10:59 PM
07/26/15 10:59 PM
ProSport
Akron, Ohio
Are the 3 wires on your alternator harness red, green and blue?
On my car, the red is not used at all. Green goes to the switched fuse box. Blue goes to the large stud on the starter relay which is always hot/powered.
#1878783
07/26/15 11:29 PM
07/26/15 11:29 PM
Al_Alguire
Las Vegas
Will depend on alternator used, whos it is. If it is a stock type application then the above referenced link is good. Some aftermarkets are True one wire others require 2 wires
#1878826
07/27/15 12:04 AM
07/27/15 12:04 AM
ProSport
Akron, Ohio
That is correct Al, mine is a Denso out of a Toyota. It is not a one-wire alternator.
[Re: ProSport]
#1879028
07/27/15 12:20 PM
07/27/15 12:20 PM
Thumperdart
State of confusion
That is correct Al, mine is a Denso out of a Toyota. It is not a one-wire alternator. Same here and wired like ProSport suggested.....14.7 at idle.
#1879669
07/28/15 12:32 AM
07/28/15 12:32 AM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Not to throw a wrench in the thread, but Can an electric shop modify a stock Mopar 37 amp alt to put out substantially more juice and also more at idle. In other words hop up the guts in a stock unit?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#1879824
07/28/15 08:07 AM
07/28/15 08:07 AM
ProSport
Akron, Ohio
There's a shop 10 min from my house in Akron Ohio that rebuilds and modifies alternators, their number is 330-535-9514.
