dodge 2500 bangs when going down the road #1872920
07/18/15 03:16 PM
07/18/15 03:16 PM
United states wisconsin
bigblockbryan Offline OP
Okay so here is my problem,I have a 1995 dodge 2500 Cummins 4x4 5 speed and when I'm going down the road it skips and bangs really loud like someones banging on my transfer case with a mall but I disconnected my front d shaft and I all ready have the 5th gear but upgraded I still have all my gears no grinding just bring also popped my diff cover and looks like new thanks
Re: dodge 2500 bangs when going down the road [Re: bigblockbryan] #1872935
07/18/15 03:30 PM
07/18/15 03:30 PM
The reason I pulled the drive shaft I thought maybe chain got stretched so I pulled it off to see if the popping and skipping went would go away
Re: dodge 2500 bangs when going down the road [Re: bigblockbryan] #1872945
07/18/15 03:39 PM
07/18/15 03:39 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If the transfer case has internal issuses removing one drive shaft isn't going to tell you much of anything.
Re: dodge 2500 bangs when going down the road [Re: stumpy] #1878238
07/26/15 02:11 AM
07/26/15 02:11 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Its more than likely the front shift fork is worn out in the transfer case , its an easy fix. It will lose high range soon if thats the problem
