E-body shifter linkage rubber boot #1877103
07/24/15 09:46 AM
07/24/15 09:46 AM
P
PasiR Offline OP
PasiR  Offline OP
P
Anyone reproduce rubber boot for slapstick linkage vertical rod?
Re: E-body shifter linkage rubber boot [Re: PasiR] #1877386
07/24/15 05:26 PM
07/24/15 05:26 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Absolutely, you will have to cut the bottom arm off to install the boot and re-weld the arm back on. The original boot was installed before the arm was welded on. Call Herb's Parts for the boot, I have none left.
Re: E-body shifter linkage rubber boot [Re: HEMICUDA] #1877408
07/24/15 06:22 PM
07/24/15 06:22 PM
P
PasiR Offline OP
PasiR  Offline OP
P
Thanks Mike!
