Re: Should 500" stroker start easily on 91 pump gas [Re: Blusmbl] #1872757
07/18/15 05:42 AM
07/18/15 05:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By Blusmbl
Originally Posted By 383man
The lower octane rated fuel will burn faster and should be easier to start the eng on. I know in the colder weather in the winter my buddies 68 Cuda thats an 11.5 Indy headed 440 will start easier on the pump then it does on race fuel since the race fuel is slower burning. Course my 63 always starts easy on the 92 pump I run. Ron
It's not just the octane- fuel purchased from a pump in the colder months in northern climates has better cold start characteristics than summer blend fuel. It's more volatile, even for the same octane rating.
I agree as you are right. drive Ron
Re: Should 500" stroker start easily on 91 pump gas [Re: 68charger440strk] #1873641
07/19/15 05:35 PM
07/19/15 05:35 PM
SW pa
goldenlancer Offline
SW pa
does the motor have a good ground?
N/SS
Re: Should 500" stroker start easily on 91 pump gas [Re: 68charger440strk] #1873842
07/19/15 10:01 PM
07/19/15 10:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Your deal, pump gas at your altitude, needs to be tuned on all the circuits properly to avoid the spark plug fouling your having up work Work on one circuit at a time, I would start on the idle circuit first, does your current carb. have four corner idle? If not try opening the rear throttle blades more to help lean out the front, close the fronts up to set the idle RPM scope I would probally restrict the idle fuel feed and the transition fuel feed holes into the main body to be about half the diameter the holes are now scope Carbs can be a pain in the butt runaway But thier all tuneable up You can fix it up Do it one step at a time scope
Re: Should 500" stroker start easily on 91 pump gas [Re: Cab_Burge] #1873891
07/19/15 10:31 PM
07/19/15 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hey Cab, on 4150`s I noticed that opening the secondaries can actually make em richer if you expose the t-slot which I generally do NOT do but, there`s a fine line and although I set up Dominators square to start, not the same w/4150`s. I personally set the primary w/a square t-slot then just crack the secondaries and adjust from there.....HOT.....running temp has the final say. thumbs
Re: Should 500" stroker start easily on 91 pump gas [Re: Cab_Burge] #1874530
07/20/15 07:49 PM
07/20/15 07:49 PM
colorado
68charger440strk Offline OP
colorado
I was out of town all weekend. I have had the slots at all reasonable positions. It is a two corner carb. I think my throttle shaft is so sloppy that the exposure of the slots changes every time I blip the throttle. It runs great off idle and no dead spots, so it is just the idle circuit that is a problem.
Re: Should 500" stroker start easily on 91 pump gas [Re: 68charger440strk] #1877073
07/24/15 04:03 AM
07/24/15 04:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Any update with the Carter carb?
Re: Should 500" stroker start easily on 91 pump gas [Re: 68charger440strk] #1877215
07/24/15 01:05 PM
07/24/15 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why not buy a billet base plate?
