Pedal now does not return high enough at rest to turn off brake lights.
It's about 1/4" shy.
Is there an adjustment to move the switch?
Not sure if you can squeeze out another 1/4" of adjustment there. The adapter means the pushrod is located farther forward (shorter in effect) plus the alum MC MAY have a thicker mounting flange and MAY have a deeper recess in the rear piston "thimble" both of which shorten the pushrod even further. I've run across 2 different lengths of manual pushrods (may be more) & the easy solution might be the MP adjustable one. Loosen the bracket & you'll have your ans in 2 minutes
