Cowl hood air box #1875287
07/21/15 08:27 PM
07/21/15 08:27 PM
Colorado Springs, Colorado
Dartthunder340 Offline OP
Could I please get some ideas or pics of air boxes with cowl hoods? I would like to build one for my Dart to see if it helps any. Thanks. Also, I have easier access to plexiglass than aluminum, would that be okay to use or should I just go get some aluminum?
Better get inside Ma. Looks like a storm's comin'.
Re: Cowl hood air box [Re: Dartthunder340] #1875758
07/22/15 02:13 PM
07/22/15 02:13 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
The best setup would be to run the pan from core support to firewall and wider than the scoop to keep out the hot under hood air and to seal the scoop to the carb.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Cowl hood air box [Re: Dartthunder340] #1876076
07/22/15 08:54 PM
07/22/15 08:54 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Here's a picture of the one I did with a 4" cowl. I did also add some rubber strips on the two short front sections.
