Amp gauge wiring question.
#1873916
07/19/15 11:05 PM
07/19/15 11:05 PM
Posts: 114 Oregon
Wagonman1967
I saw a post about retrofitting the amp gauge wiring but cant find.Point me in the right direction Please.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
Re: Amp gauge wiring question.
[Re: Wagonman1967]
#1873929
07/19/15 11:18 PM
07/19/15 11:18 PM
Posts: 1,443 Maryland
Dads426
Maryland
I think this is what you are looking for: Mad Electric
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1873988
07/20/15 12:00 AM
07/20/15 12:00 AM
RapidRobert
the Mad system bypasses the OE ammeter which renders it inaccurate & does keep alot of current out of the dash side of the bulkhead/firewall. Another option (my pref) is to keep the ammeter functioning (I'm old school I like it) & (1) replace the (4) brass terminals in the bulkhead which handle the main in/out current with (2) lengths of wire by drilling out the four bulkhead cavities (Nachos bulkhead parallel bypass) (2) cleaning EVERY terminal/connection (3) relaying the headlights/AC/heater directly to the alt in the eng bay (4)largest crank pulley/smaller alt pulley (there's 2 sizes) (5) adequate capacity battery (6) better alt in some cases (7) add a switched 12V voltmeter. Ma's system worked well most all the time & taking off some of the load (lights etc) makes it even less likely to ever be problematic & I like my ammeter. If you dont mind losing the ammeter the Madd people do know their stuff
[Re: Wagonman1967]
#1874034
07/20/15 01:11 AM
07/20/15 01:11 AM
Posts: 114 Oregon
Wagonman1967
Just what I was looking for. Thanks.
[Re: RapidRobert]
#1874516
07/20/15 07:26 PM
07/20/15 07:26 PM
Posts: 4,290 Morrow, OH
markz528
Morrow, OH
the Mad system bypasses the OE ammeter which renders it inaccurate & does keep alot of current out of the dash side of the bulkhead/firewall. Another option (my pref) is to keep the ammeter functioning (I'm old school I like it) & (1) replace the (4) brass terminals in the bulkhead which handle the main in/out current with (2) lengths of wire by drilling out the four bulkhead cavities (Nachos bulkhead parallel bypass) (2) cleaning EVERY terminal/connection (3) relaying the headlights/AC/heater directly to the alt in the eng bay (4)largest crank pulley/smaller alt pulley (there's 2 sizes) (5) adequate capacity battery (6) better alt in some cases (7) add a switched 12V voltmeter. Ma's system worked well most all the time & taking off some of the load (lights etc) makes it even less likely to ever be problematic & I like my ammeter. If you dont mind losing the ammeter the Madd people do know their stuff Pretty much what I did.
