smallblock head choices for a warmed over street dart #1873749
07/19/15 08:17 PM
07/19/15 08:17 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
My son just bought a 73 dart with a 318/904 combo and is mulling over the idea of turning up the power by building a nice pump gas 360/408 stroker deal, head selection is one of the first things on the list as everything below them is kind of dictated as to what head, chamber volume, chamber design, port size/volume,etc you have to work with,, with the exception of Edelbrocks, (which I have no beef with) what aftermarket heads are available to give good service life and make reasonable power for a car that will be 95% street and once in a great while a trip to the track. work
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1873756
07/19/15 08:30 PM
07/19/15 08:30 PM
AndyF Offline
AndyF  Offline
I'd probably use an Edelbrock aluminum Magnum head on an engine like that. The Magnum head gives you a bunch of nice upgrades over the standard LA design.
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1873762
07/19/15 08:40 PM
07/19/15 08:40 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
You might as well just put a big W head motor in it now, cause you know how its gonna end up. smile
Re: smallblock head choices for a warmed over street dart [Re: AndyF] #1873763
07/19/15 08:44 PM
07/19/15 08:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
9.73@135 mph with more left on a worn out 408 so you know what head I would recommend (edelbrocks). He can do a slight clean-up on them now and port them went he needs more power. When and if he wants something better down the road he still has a very sell-able head.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1873769
07/19/15 08:53 PM
07/19/15 08:53 PM
Az
Crizila Offline
Crizila  Offline
Az
If you are not going crazy with anything, mostly street use, I would buy a pair of indy cast iron LA heads for around $499. Most are 915 castings with 2.02 intakes - new valves, guides, springs, seals, and valve job. Take them apart, do some pocket port work on them and port matching. If you are running a mild hydraulic cam, you can use most of your existing valve train over again ( and intake ). For the $, best bang for the buck out there IMO for a street small block. As mentioned, aluminum Eddy magnums would be a nice step up in performance from my suggestion, but more $. That's what's sitting in this project.
Fastest 300
Re: smallblock head choices for a warmed over street dart [Re: Hot 340] #1873877
07/19/15 10:21 PM
07/19/15 10:21 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
sorry but a w-headed anything will go in mine first.LOL
Re: smallblock head choices for a warmed over street dart [Re: AndyF] #1873882
07/19/15 10:23 PM
07/19/15 10:23 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
that sounds interesting. work
Re: smallblock head choices for a warmed over street dart [Re: AndyF] #1873913
07/19/15 11:03 PM
07/19/15 11:03 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Outstanding advice.
Hard to beat the performance capability and casting quality of Eddies.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874049
07/20/15 01:24 AM
07/20/15 01:24 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
W2 heads. I love em on simple cool street builds
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874083
07/20/15 02:25 AM
07/20/15 02:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Maybe the indy RHS X head that Brian at IMM sells. His CNC ported ones might even be better
http://www.immengines.com/indyimmironheads.html
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874089
07/20/15 02:38 AM
07/20/15 02:38 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Andy F......Can ya let us know what those upgrades are??? What about the Indybrock heads??
Re: smallblock head choices for a warmed over street dart [Re: SpareParts] #1874218
07/20/15 12:12 PM
07/20/15 12:12 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I thought about those also but he definately wants an aluminum head, I had even thought about putting my lg port commando's on his but the new victors seem to be a unlikely choice for me since Edelbrock seems to not want to sell them.
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874330
07/20/15 02:40 PM
07/20/15 02:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Brett has the pro comps flowing well.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874391
07/20/15 04:02 PM
07/20/15 04:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Your only going to go so fast with an Eddie or a pro comp, no matter which you use.
No way I would go with the inferior casting quality of a pro comp for something that going to be driven on the street a lot.
Eddie is a known good, long term reliable head, same is far from having been proven with the procomp.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874436
07/20/15 05:14 PM
07/20/15 05:14 PM
CJD AUTOMOTIVE Offline
I've got a set of new ported Brodix B1-BA's with new Jesel shafts that I'll make you a killer deal on. Don't know why they had so many variants in this head as far as flow, but this set is 314 cfm @ .600 with awesome low lift numbers. Koffel's did the port , flow, and valve work. They designed them and seem to know how to make them work.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: smallblock head choices for a warmed over street dart [Re: CJD AUTOMOTIVE] #1874545
07/20/15 08:11 PM
07/20/15 08:11 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Best bank for the buck? Two letters: EQ
Up to 450 HP: As cast valve sizes, bolt em on and go.
Up to 580-ish HP: With 2.02 intakes and very slight porting.
While you have to run magnum rockers, it helps that you can get OE replacements for less than $100. Bonus: 1.6 ratio.
You can even get them drilled for an LA intake!
You're welcome : )
Re: smallblock head choices for a warmed over street dart [Re: dartman366] #1874644
07/20/15 10:25 PM
07/20/15 10:25 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
We should ask, how fast your boy hoping to go?
I dig this, I'm a young dude too, went sorta fast at 326" with W2 heads on a budget with a bottle
Re: smallblock head choices for a warmed over street dart [Re: B3422W5] #1874665
07/20/15 10:44 PM
07/20/15 10:44 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
As sad is it is to say Don the pro comp that I did back to back with E - heads I was doing at same time pro comp was nicer head.......
Re: smallblock head choices for a warmed over street dart [Re: SpareParts] #1874695
07/20/15 11:12 PM
07/20/15 11:12 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I don't know but he told me last night he scored a dana for it. work work
Re: smallblock head choices for a warmed over street dart [Re: CJD AUTOMOTIVE] #1874713
07/20/15 11:27 PM
07/20/15 11:27 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
now you just made me slobber all over my keyboard.lol
