Re: Power Steering Fluid
[Re: JFChallenger440]
#1873412
07/19/15 11:37 AM
07/19/15 11:37 AM
Posts: 216 E. Okla line
m88mark
E. Okla line
What power steering fluid should I be putting in my 69 Coronet ? I have ATF Type F for my 70 Mustang, would that be ok ? Also should the cap be vented ? It does say vented on it but I can't see any holes on it, I have fluid coming out of the top on full lock, thanks Disadvantage of type F, if you have a leak it eats rubber, tie rod boots, ball joints, etc. Probably still has air in the system pushing fluid out can be a bitc_ to bleed sometimes.
[Re: m88mark]
#1873613
07/19/15 04:42 PM
07/19/15 04:42 PM
Posts: 26,522 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disadvantage of type F, if you have a leak it eats rubber, Isn't there rubber within the system?
[Re: John_Kunkel]
#1873640
07/19/15 05:34 PM
07/19/15 05:34 PM
m88mark
E. Okla line
Disadvantage of type F, if you have a leak it eats rubber, Isn't there rubber within the system? Well he** John every time I think I've got something figured out somebody uses reason. But every time I've had ps leaks for extended time my rubbers swell & turn soft. I know fix my leaks but
[Re: m88mark]
#1873659
07/19/15 06:11 PM
07/19/15 06:11 PM
Posts: 534 SW CO
HemiSportFury
SW CO
Back in the day I ran ATF but now I just run power steering fluid.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
#1873714
07/19/15 07:27 PM
07/19/15 07:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe the spec is for PS fluid, not any ATF. Some have run ATF, but the only time ATF ever got into my system (thanks wifey) I soon had a major leak at the pitman shaft seal. That one is a PITA to replace without the special factory tools in the car.
[Re: Supercuda]
#1874400
07/20/15 04:14 PM
07/20/15 04:14 PM
John_Kunkel
Rio Linda, CA
I believe the spec is for PS fluid, not any ATF. Some have run ATF, but the only time ATF ever got into my system (thanks wifey) I soon had a major leak at the pitman shaft seal. The leak occurred because of the change in fluid, not what fluid was changed to. Common with aged seals. Some of the rubber in later P/S systems is the exact same (even the same part number) that was in units back when ATF was the P/S fluid of choice.
