Re: Should 500" stroker start easily on 91 pump gas
[Re: Blusmbl]
#1872757
07/18/15 05:42 AM
07/18/15 05:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The lower octane rated fuel will burn faster and should be easier to start the eng on. I know in the colder weather in the winter my buddies 68 Cuda thats an 11.5 Indy headed 440 will start easier on the pump then it does on race fuel since the race fuel is slower burning. Course my 63 always starts easy on the 92 pump I run. Ron It's not just the octane- fuel purchased from a pump in the colder months in northern climates has better cold start characteristics than summer blend fuel. It's more volatile, even for the same octane rating. I agree as you are right. ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) Ron
[Re: 68charger440strk]
#1873641
07/19/15 05:35 PM
07/19/15 05:35 PM
Posts: 440 SW pa
goldenlancer
SW pa
does the motor have a good ground?
N/SS
#1873842
07/19/15 10:01 PM
07/19/15 10:01 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
Your deal, pump gas at your altitude, needs to be tuned on all the circuits properly to avoid the spark plug fouling your having ![work work](/ubbthreads/images/graemlins/custom/work.gif) Work on one circuit at a time, I would start on the idle circuit first, does your current carb. have four corner idle? If not try opening the rear throttle blades more to help lean out the front, close the fronts up to set the idle RPM ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I would probally restrict the idle fuel feed and the transition fuel feed holes into the main body to be about half the diameter the holes are now ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Carbs can be a pain in the butt ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) But thier all tuneable ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) You can fix it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Do it one step at a time ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#1873891
07/19/15 10:31 PM
07/19/15 10:31 PM
Thumperdart
State of confusion
Your deal, pump gas at your altitude, needs to be tuned on all the circuits properly to avoid the spark plug fouling your having ![work work](/ubbthreads/images/graemlins/custom/work.gif) Work on one circuit at a time, I would start on the idle circuit first, does your current carb. have four corner idle? If not try opening the rear throttle blades more to help lean out the front, close the fronts up to set the idle RPM ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I would probally restrict the idle fuel feed and the transition fuel feed holes into the main body to be about half the diameter the holes are now ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Carbs can be a pain in the butt ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) But thier all tuneable ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) You can fix it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Do it one step at a time Hey Cab, on 4150`s I noticed that opening the secondaries can actually make em richer if you expose the t-slot which I generally do NOT do but, there`s a fine line and although I set up Dominators square to start, not the same w/4150`s. I personally set the primary w/a square t-slot then just crack the secondaries and adjust from there.....HOT.....running temp has the final say. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Cab_Burge]
#1874530
07/20/15 07:49 PM
07/20/15 07:49 PM
Posts: 16 colorado
68charger440strk
colorado
Your deal, pump gas at your altitude, needs to be tuned on all the circuits properly to avoid the spark plug fouling your having ![work work](/ubbthreads/images/graemlins/custom/work.gif) Work on one circuit at a time, I would start on the idle circuit first, does your current carb. have four corner idle? If not try opening the rear throttle blades more to help lean out the front, close the fronts up to set the idle RPM ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I would probally restrict the idle fuel feed and the transition fuel feed holes into the main body to be about half the diameter the holes are now ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Carbs can be a pain in the butt ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) But thier all tuneable ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) You can fix it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Do it one step at a time I was out of town all weekend. I have had the slots at all reasonable positions. It is a two corner carb. I think my throttle shaft is so sloppy that the exposure of the slots changes every time I blip the throttle. It runs great off idle and no dead spots, so it is just the idle circuit that is a problem.
#1877215
07/24/15 01:05 PM
07/24/15 01:05 PM
Thumperdart
State of confusion
Your deal, pump gas at your altitude, needs to be tuned on all the circuits properly to avoid the spark plug fouling your having ![work work](/ubbthreads/images/graemlins/custom/work.gif) Work on one circuit at a time, I would start on the idle circuit first, does your current carb. have four corner idle? If not try opening the rear throttle blades more to help lean out the front, close the fronts up to set the idle RPM ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I would probally restrict the idle fuel feed and the transition fuel feed holes into the main body to be about half the diameter the holes are now ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Carbs can be a pain in the butt ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) But thier all tuneable ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) You can fix it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Do it one step at a time I was out of town all weekend. I have had the slots at all reasonable positions. It is a two corner carb. I think my throttle shaft is so sloppy that the exposure of the slots changes every time I blip the throttle. It runs great off idle and no dead spots, so it is just the idle circuit that is a problem. Why not buy a billet base plate?
