Ram truck blend door repair #1872297
07/17/15 01:40 PM
07/17/15 01:40 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
So I have had my 2005 crew cab fixed several years ago and now the new 05 single cab I just bought has the same problem. The air is cold but will not change to the defrost,floor or other vents. It blows hard but does not come out really anywhere very good. I looked on you tube and have not found a good video yet. Anyone know of a good one that shows how to fix the problem. Money is a little tight and I hate to spend $600 on a repair at the shop.
Re: Ram truck blend door repair [Re: fastmark] #1872346
07/17/15 03:20 PM
07/17/15 03:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Ram truck blend door repair [Re: John_Kunkel] #1872624
07/17/15 11:21 PM
07/17/15 11:21 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Those guys talk about cutting into the box and then repairing it. Not sure if that is what I need to do.
Re: Ram truck blend door repair [Re: fastmark] #1872664
07/18/15 12:42 AM
07/18/15 12:42 AM
Maryland
regularjay Offline
regularjay  Offline
Maryland
I used a heatertreater kit on my 99 Grand Cherokee that involved cutting into the box and coupling the flaps for both sides up to one motor worked great for about 4 years till I sold the truck, easy hour long project that worked out fine.
79 Lil Red Express - I'll finish it someday
94 2wd Ram 1500 5.9 Donor for...???
78 CJ7 4.2 with Clifford Cam, Holley 390, 4" on 33's
1992 W250 Cummins
2013 Ram 4X4 Hemi Crew Express
2005 Ex Cab Dakota 4x4 4.7 Daily Driver
1993 2wd Ramcharger 5.2/auto
Re: Ram truck blend door repair [Re: regularjay] #1872684
07/18/15 01:06 AM
07/18/15 01:06 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
I had same problem. Blend door broke off and landed on top of blower fan. Could here fan blowing hard but hardly any air coming out. I removed glove box door, then cut out part of the plastic covered up by the door, ( you wont see it once you put the door back on). Then removed blower motor and could reach up into the ducting and remove the door. I cheaped out and taped the door back in place over fresh air vent. I wasn't concerned about getting fresh air in.
To fix it correctly you will prob have to replace the electric motor that opens and closes the door and the door since it will probably have the splined end broken off.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Ram truck blend door repair [Re: fastmark] #1872775
07/18/15 09:55 AM
07/18/15 09:55 AM
ky.
K
kenworth_goose Offline
K
ky.
Do it the right way, pull the dash, remove the heater box, replace all of the actuators and doors along with the heater core and evaporator and be done with it. The last one I did it took about 4 hours.
Re: Ram truck blend door repair [Re: fastmark] #1872826
07/18/15 12:15 PM
07/18/15 12:15 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well the heater and AC work fine so don't want to replace all of that. My bud at the dealership told me that I really need to pull the dash out on the right side and just replace the one blend door. A good tech can do it in can hour or so. Think I'll try that. The new part is can improved design.
Re: Ram truck blend door repair [Re: fastmark] #1873524
07/19/15 02:27 PM
07/19/15 02:27 PM
GEORGIA
barracuda7199 Offline
GEORGIA
Heater treater is the way to go! Can't beat a steel door! The motors are to strong that close the doors is what breaks them. If the recirc door is broke you can remove the blower motor and pull the broke door out in about 10 minutes.
Re: Ram truck blend door repair [Re: fastmark] #1873578
07/19/15 04:01 PM
07/19/15 04:01 PM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
If I'm not mistaken....there is an updated blend door "housing" assembly for that year 05/06 truck....?? I can check tomorrow when I get to work if you want? To help clarify, I would just need the last 8 digits of your VIN and can tell you for sure....?
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Ram truck blend door repair [Re: fastmark] #1873585
07/19/15 04:14 PM
07/19/15 04:14 PM
ky.
K
K
ky.
Every single one that I've done has needed every door replaced. This is a very common problem on the later rams trucks. Should have been a recall from Chrysler but won't ever happen. I'm an over doer so I tend to do things before I need to or have to. Good luck.
Re: Ram truck blend door repair [Re: fastmark] #1873636
07/19/15 05:24 PM
07/19/15 05:24 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I been putting it off for two years on my 06 3500, getting harder to like these guys from Chrysler with all the issues mine has or had. Injectors now. Seems like we're returning to the 60s or earlier, when they where sold or traded after they got 50,000 miles.
Re: Ram truck blend door repair [Re: fastmark] #1873997
07/20/15 12:05 AM
07/20/15 12:05 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Yes there is an updated housing but you have to pull the dash out on the pass side to get to it to change it. I just bought the truck for my wife and she says not to mess with it for now. It works good enough to the time being. I've got a charger and a barracuda in the shop to sell and they are just labor intensive to get ready to go.
Re: Ram truck blend door repair [Re: fastmark] #1874028
07/20/15 12:56 AM
07/20/15 12:56 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Go over to http://www.dieseltruckresource.com/ and poke around. Someone did a detailed write up a few years ago on how to change the door. I printed out the instructions, and did mine in about an hour. You don't actually remove the dash. You just rock it back out of the way, so you have room to work. Good luck.
Re: Ram truck blend door repair [Re: JDMopar] #1875453
07/21/15 11:58 PM
07/21/15 11:58 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Ram truck blend door repair [Re: fastmark] #1875885
07/22/15 05:14 PM
07/22/15 05:14 PM
southern illinois
O
ozz383 Offline
ozz383  Offline
O
southern illinois
I did the heatertreater kit on mine. Worth every penny. mine had the updated housing when i got it. It broke also. there stuff is an easy install they have videos on youtube.
Re: Ram truck blend door repair [Re: ozz383] #1880726
07/29/15 01:40 PM
07/29/15 01:40 PM
Wichita,ks.
jst19600 Offline
jst19600  Offline
Wichita,ks.
Im getting my 2003 diagnosed tomorrow.I have air coming out all vents just dont have the airflow that i should.Shop is going to run a scope down the vents to to see where the problem lies.
