Re: Small block oil pan gasket issue
[Re: tippytoe]
#1872579
07/17/15 10:22 PM
07/17/15 10:22 PM
Posts: 13,605 md
mopars4ever
md
I don`t think 70 up used those rubber tabs around the pan. Do you have some pics of the old oil pan end seals and the new ones? You may want to try a different brand gasket. Does it look like this? http://www.ebay.com/itm/Victor-OS30520X-...f06&vxp=mtr
[Re: mopars4ever]
#1872697
07/18/15 01:25 AM
07/18/15 01:25 AM
RapidRobert
early 64-69 318 pan has (6) holes for front seal. '70 up (318) has (2) holes (one bigger than the other) & both ends take the same gasket. If you have the correct gaskets & the broken nubs are interfering you might cut them flush so the gasket will fit close then use some killer gasket cement like "the right stuff". More info, what do you have/whats going on
[Re: tippytoe]
#1873650
07/19/15 05:51 PM
07/19/15 05:51 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My new leaking pan and gasket are on my E58 360. I had mechanic install it and it's leaking bad. I was told that the end gasket goes on the bottom of the side gasket at rear, and on top at the front, and maybe the mechanic did that wrong. The other suggestion was to buy a Superformance gasket as they are very high quality. I've yet to pull the pan myself and give it a shot, so I don't know how the end gaskets went in. I can see plenty of sealant though. The 360 and 318 use different pan, but maybe some of this applies. I think it was RapidRobert who gave me the placement of the gasket tip and Scratchinfortraction the gasket tip. They are reliable sources
Facts are stubborn things.
[Re: tippytoe]
#1873715
07/19/15 07:28 PM
07/19/15 07:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No need, I don't have oil pan leaks to sweat.
[Re: larrymopar360]
#1874406
07/20/15 04:21 PM
07/20/15 04:21 PM
Posts: 15,487 Florida
scratchnfotraction
My new leaking pan and gasket are on my E58 360. I had mechanic install it and it's leaking bad. I was told that the end gasket goes on the bottom of the side gasket at rear, and on top at the front, and maybe the mechanic did that wrong. The other suggestion was to buy a Superformance gasket as they are very high quality. I've yet to pull the pan myself and give it a shot, so I don't know how the end gaskets went in. I can see plenty of sealant though. The 360 and 318 use different pan, but maybe some of this applies. I think it was RapidRobert who gave me the placement of the gasket tip and Scratchinfortraction the gasket tip. They are reliable sources I sure can tell you the oil pan on the 89-318 I got from you was sealed to the block for sure. not sure if you had it changed before, but it had some killer black rtv with a cork gasket/metal center that I had to hammer a flat putty knife down both sides of the block to cut it loose.
[Re: mopars4ever]
#1874520
07/20/15 07:29 PM
07/20/15 07:29 PM
RapidRobert
if you have the right gasket but the nibs are a bit too big you can drill out the pan holes easily enough (assuming everything else is spot on) but yes it would be better to get ones that fit. As said make sure it is the right one
[Re: mopars4ever]
#1874959
07/21/15 11:02 AM
07/21/15 11:02 AM
Posts: 828 Winchester, In
tippytoe
Winchester, In
The reason I asked was that I installed a pan gasket on a 318 many years ago and had the same issue as you with the rubber nubs being too big. I vaguely remember that I ended up using a diiferent brand gasket IIRC. That's the avenue I am going to try today. Got hammered with overtime at work & haven't had a chance to work on my car since I posted.
[Re: scratchnfotraction]
#1876350
07/23/15 01:26 AM
07/23/15 01:26 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My new leaking pan and gasket are on my E58 360. I had mechanic install it and it's leaking bad. I was told that the end gasket goes on the bottom of the side gasket at rear, and on top at the front, and maybe the mechanic did that wrong. The other suggestion was to buy a Superformance gasket as they are very high quality. I've yet to pull the pan myself and give it a shot, so I don't know how the end gaskets went in. I can see plenty of sealant though. The 360 and 318 use different pan, but maybe some of this applies. I think it was RapidRobert who gave me the placement of the gasket tip and Scratchinfortraction the gasket tip. They are reliable sources I sure can tell you the oil pan on the 89-318 I got from you was sealed to the block for sure. not sure if you had it changed before, but it had some killer black rtv with a cork gasket/metal center that I had to hammer a flat putty knife down both sides of the block to cut it loose. Nope, I never changed it and was told it was original. It was bone dry under that engine, I remember that.
[Re: tippytoe]
#1879261
07/27/15 04:36 PM
07/27/15 04:36 PM
RapidRobert
Pan sealed great & doesn't leak. Success!
